Previous in Forum: orifice plate upstream straight run   Next in Forum: Linear and equal percent characteric of control valve
4~20mA Current Injector
02/08/2009 11:55 PM
Dear All,
Can we DIY a 4~20mA injector, a 3 steps required, from 4,12 and 20mA.
Thanks
Re: 4~20mA Current Injector
02/09/2009 12:44 AM
give the complete data
South Africa - Member -
Good Answers: 12
02/09/2009 1:40 AM
Hi there,
Yes you can. You need to build a simple current divider circuit. Try that great encyclopedia google for current divider circuits.
Regards,
Craig
02/09/2009 3:55 AM
Yes very simply if you have a even little experience in electronics.
A couple of 9v batteriers and an LM317 (National have great data sheets on it just google LM317 and read the application notes.)
you'll need a few other components.
If yo aren't too worried about accuracy, you could probably just use 2 pp3 batteries in series and a resistor in series for each current.
02/09/2009 2:18 PM
At last a reply that addresses the problem!
A GA from me...
02/10/2009 6:50 AM
TRY THIS CIRCUIT.
02/10/2009 10:44 AM
That circuit will only do 0 to 5 mA....
Using a 7805 the resistors need to be.... 220Ω with a pot of 500Ω in series to cover 4 to 20 mA
07/11/2010 6:15 AM
But 220 ohm series with 500 ohm = 720 so minimum current would be 6.94 mA...
so POT. should more than 500k..
Anonymous Poster (1); craigza (1); Electroman (2); faith37 (1); jamsshed (1); user-deleted-1105 (1)
