I have a project that I need some advice on. problem is that I am not sure how to ask it as a forum question.
Basically what I want to do is make a heating element out of wire
mesh. The element needs to get hot enough to melt material such as hot
glue. The element will be placed on the sheet (hot glue or similar) and
heated so that the top surface of the plastic melts and passes through
the mesh element slightly (imbedding). At this time another material
(textile) will be placed on top of the molten plastic (glue) and all
allowed to cool - making one laminated product.
The heating element needs to be very flexible. Very thin, and very cheap.
I am thinking I can disassemble a variable temp soldering iron and
install 2 leads that are soldered to the mesh (sacrificial heating
element) to transfer heat. That or gutting a toaster oven.
