Previous in Forum: Mac vs PC vs Linux   Next in Forum: Nitrobacter, nitrosoma for aquarium water filtering
13 comments
Good Answers: 97
Tuning a Ibanez RG320
02/22/2009 3:32 PM
I bought my grandson a Ibanez
It seems next to impossible to tune the dam thing.
Can anyone supply me with a detailed view or a link showing and naming all the components?
What is the best procedure for tuning?
Good Answers: 38
Re: Tuning a Ibanez RG320
02/22/2009 3:51 PM
All tuning should be done at the top of the neck with the adjustment (tuning) pegs. The section in your photo is to adjust the string height and position over the pickups. This is so the strings do not touch the frets and cause buzzing when played but allow the pickups to be as close as possible. There are many cheap and affordable tuners that you can purchase to make sure it is tuned in the proper key. That may make it easier. If the lower portion was adjusted and you are not familiar with the process of alignment or adjustment you may want to bring it in for service.
Look here. http://www.ibanezrules.com/tech/setup/action.htm
The last fight was my fault. My wife asked "What's on the TV?" I said "Dust!"
02/22/2009 11:38 PM
Okay, the trouble you are having is with the Floyde Rose licensed floating vibrato system. You tune one string, then another, then the one you just tuned is out of tune again because the bridge has moved accordingly. I find that if I start by tuning the low E string all the way up to G when I have installed new strings that, by the time I have tuned all the others to pitch (from lowest to highest), the low E string will be approximately at pitch (as will the others). You'll probably have to go back through it a couple times to bring each string closer to pitch. Just remember that when you tighten one string you're loosening all the others (and vice versa). When it's in tune, tighten down that locking-nut and use the fine-tuners on the bridge for any subsequent adjustments.
Good Answers: 16
02/23/2009 12:38 AM
I presume this is a new guitar? If so, it might need a bit of "accurizing". Slang word, I know. The first step to improve the tunability of a guitar is to inspect and correct the nut if necessary. If the string slots are not cut deeply enough the pressure to force the string to the neck can cause a slight intonation problem. This is corrected (carefully!) with nut files and a skilled finger. One should be able to depress the string as hard as possible and not cause a tonal shift. The strings also should not "buzz" against any frets when played open. That is often attributed to saddle height but the nut must be inspected first.
Next comes the neck. I presume it has the proper curvature-this is easy to test. Depress each string at fret 12 and check the clearance between the depressed spring and neck at about fret five or fret 6. There should be sufficient clearance so strings do not buzz. I usually pluck the section of the string that lies between fret 12 and the nut and listen for buzzing. A piece of folded paper also makes a good gauge to determine whether the clearance is sufficient. "Just enough" is the correct amount, and that depends greatly on the gauge of strings chosen, and on the technique of the guitarist. The neck has a truss rod that can be turned (carefully!) to change the curvature of the neck.
Finally, there is the saddle-often referred to as the bridge. The saddle pictured in an adjustable unit for string length and string height. This is set last, after the nut and neck are deemed to be correct or nearly correct. The saddle must be high enough so the strings do not "buzz" against any of the frets between the fret used and the saddle. The distance between the nut and the saddle can be adjusted as well for the purpose of correcting harmonics. This is best done with an electronic tuner that can interpret octaves - most can these days. I think you will find that any adjustment you make will affect all others, and since each compliments or compounds the other it can take a bit of time. Perhaps a visit to the local guitar shop or the local guitar hotshot is in store for you?
Finally, you have that danged "wang bar" on this guitar. The gauge of strings used will determine the number or size of springs used to balance the string tension - if this one has the option of adjustment. Essentially, lighter strings require less spring preload.
Here's a website that covers a bit of this work: http://www.guitargearheads.com/modules/news/article.php?storyid=44<br%20/>
You can no doubt find some more things out in Cyberspace. I really think if the strings are matched to the spring tension that it will be a good start. Is this your nephew's first electric guitar? If so, he may need to become accustomed to the very light string gauges and low string tension. I know that I have to train my fingers how to handle these things, Even after more than thirty (30) years with the guitar since the instrument I normally play is a classical with the broad, flat neck and high action. It has been a long time since I adjusted an electric guitar so it was as close to "perfect" as it can be. They are NEVER perfect, as the "B" string usually has a slight intonation issue regardless of how good everything else is.
Good Luck!
Ing. Robert Forbus
"Yeah, but will it fit?"
Good Answers: 68
02/23/2009 12:21 PM
Hello Ing. Robert Forbus:
GA for you sir!
A good answer and one which covers a lot of ground. !
Good Answers: 19
02/23/2009 7:30 PM
I heartily agree and give a second GA vote! Thank you Mr. Forbus!
03/10/2010 12:43 AM
I know this is an old thread.
Lots of people never learn to cope with these guitars. I like this link's information very much and my guitar has benefited tremendously. It was a lot of work to go through and set mine up well, but it's been so very worth the effort.
http://www.ibanezrules.com/tech/setup/index.htm
Hofstadter's Law :
It always takes longer than you expect, even when you take into
account Hofstadter's Law.
Popular Science - Biology - life lover Hobbies - Musician - music lover Safety - Hazmat - better safe than sorry United Arab Emirates - Member - desert trek Technical Fields - Procurement - procurement
Good Answers: 58
02/23/2009 4:14 AM
nice guitar. :D
for a non-musician, tuning by ear will using a piano, pitch pipe, tuning fork or keyboard as pitch reference can be a bit difficult. thus, a gadget, called electronic guitar tuner would help, as it is a purely visual tool that will assure you that you've got all the strings tuned right.
please visit this http://www.expertvillage.com/video/3272_electric-guitar-basics-tuning-devices.htm for very good step-by-step instructions on how to do this.
and, oh yes, the vendor should also be able to give his opinion on this, much more so the manufacturer: http://www.ibanez.com/eg/series.aspx?s=rg_tremolo
Now the darkness only stays the night-time, in the morning it will fade away. -- George Harrison (All Things Must Pass)
Good Answers: 97
02/23/2009 4:14 AM
Thank so far I will read and study the comments tonight.
In the mean time I bought him an electronic tuner - One of the contributing problems was that my tuning by ear method (as used successfully on his previous guitar) did not go well with the floating parts of the whammy.
I also downloaded the "rules" today.
02/23/2009 9:12 AM
The information you have received in other responses and in the Rules is very helpful to setting up the guitar for maximum playability, and if you are inexperienced it is better to take it to a guitar tech - most will make these adjustments for less than $100. If you are intent on doing it yourself, you might consider purchasing a book such as The Guitar Handbook by Ralph Denyer (no affiliation or interest). HOWEVER, your question was how to tune it, and you have received some misinformation about that in these responses. In fact, the six small knurled thumbscrews (micro-tuners) at the very bottom of the floating tremelo and bridge system ARE used to fine tune the individual strings to correct pitch. This is done after rough-tuning with the tuning pegs in the headstock, but one cannot adjust the rough tuning with the tuning pegs in the headstock until one has released the strings from the string lock, which has three allen screws which must be loosened to release the strings. This string lock serves as the nut, and is located just above the first fret, as shown in the photo below.
So, first adjust each of the micro-adjusters (six small knurled thumbscrews at the very bottom of the floating tremelo system) to the middle of their adjustment range to establish a starting point for later adjustment. Second, loosen the three allen screws in the string locks above the zero fret just enough to allow the strings to slip when the tuning pegs in the headstock are turned. Third, rough tune using an electronic tuner, but tune the strings very slightly flat, because tightening the allen screws to lock the strings will raise the pitch slightly. You may find it helpful to tighten them slightly and readjust to correct pitch using the electronic tuner again before fully tightening the allen screws. Fourth, make the fine adjustments of each string to pitch using them icro-adjusters. Once this process is completed, you should only need to tune for each playing session using the micro-tuners. Should a string stretch or slip after playing, such that the required adjustment to pitch is beyond the range of the microadjusters, then you will have to repeat the whole process.
Hope this helps!
Good Answers: 68
02/24/2009 5:36 AM
Hello snowman910,
GA to you sir. I have reread your post. Congrats.............
02/24/2009 9:26 AM
Thank you Mr. Forbus! I found your comments and your link to the Gary Allen article on setup and intonation very useful. I think Gary Allen's cautionary comments about truss rod adjustment are most important, although they should not prevent a novice from attempting to adjust the truss rod - my rule of thumb on that is to never make more than a 1/16 turn (22 degrees or so) adjustment to the truss rod in a 24 hour period. If everyone had the patience to observe that limit, there would be fewer broken necks and separated fretboards.
Good Answers: 16
02/23/2009 11:23 PM
Guys, thanks a lot for the GA's but I think the post by Snowman910 definitely gets to the "meat of the matter" so to speak and deserves a GA at least from me. He obviously has intimate knowledge of how this particular guitar is designed and is happy to share. I am not familiar with this particular guitar - just several others I have owned over the years.
Henrik, your grandson has a fantastic grandfather-that is a very nice gift for any boy. By the way, one (1) of my all -time favourite electric guitars is a 1980's vintage Ibanez "Iceman" made famous (I think) by a member of the Kiss band. Strange-looking instrument - but with a fretboard and tone quality to kill for. Far better than most of the Fender and Gibson instruments I ever owned in regards to playability and correct fret tone right off the shelf.
I still have it! It is a funny story how I acquired it though. I was invited to the local music store to test a new (at that time in history) fully-digital effects device. It was impressive, but nothing like the "cheap" guitar I found lying around the shop to use for my decision about the effects unit. "So, what do you think?" I was asked. I replied that the digital effects unit was extremely good, but that I really thought this "wierd" guitar was the most playable instrument I ever picked up. "How much?" I asked, and walked away from the stire without an effects unit, but with a very nice guitar for much less than $200.00.
Hey; this is a fun visit to the past. Thanks, Henrik!
Best Regards,
Ing. Robert Forbus (Toolmaker, Mechanical Engineer, former Heavy-Metal Wannabee)
02/24/2009 1:13 AM
Nice Axe, treat it well.
If you have problems with string buzz you may need to change the truss tension in the neck (changes the curvature). Some guitars this is a seasonal thing due to moisture.
Also once he gets so he can play well you might go to a good guitar shop and have it strobed. They use a strobe light to tune the neck and string lengths. As a novice he will not hear the difference but later it can make the difference between a good sounding guitar and a great one.
You might also get him a good beginners how to. It can save some bad habits to un learn. Or just find him a classical guitarist to show him the beginning ropes.
I can't read music for a guitar but I have thousands of pages of guitar tablature. Easy to find.
I started pre digital and don't even try to keep up with all the cool effects out now.
Brad
Register to Reply 13 comments
Anonymous Poster (1); babybear (2); charsley99 (1); clocker (1); Hendrik (1); Ing. Robert Forbus (2); langyaw (1); Ried (1); snowman910 (2); U V (1)
