Im trying to design a small evaporative cooler for a home setting using expelled air of a vacuum pump to run across a sample of brackish water-soaked wood wool in order to cool a small area such as a room. I have three questions. 1) Does evaporative cooling work by running air across a piece of wood wool or "through" a sample of wood wool? 2) is it plausible to use brackish water for this application? Should I take into consideration any effects that the salts might have on the evaporative cooling occuring? 3) Are there any special types of screens that i might need to use that cover the wood wool?
Thanks alot!
