Previous in Forum: Sliding Pressure and Industrial Boilers   Next in Forum: Carrier Gemini Split Heat Pump
water pumps HP
04/08/2009 2:05 AM
how i will calculate HP of water pumps answer me
Re: water pumps HP
04/08/2009 3:08 AM
Multiply the volumetric flowrate by the pressure rise and divide by the efficiency.
Re: water pumps HP
04/08/2009 3:25 AM
That's a rather dry answer ..tee hee
Are you going flat out for the 100 GAs today?...you seem to have answered every post and the kettles hardly had time to boil .
Re: water pumps HP
04/08/2009 3:27 AM
Good Answers: 103
Re: water pumps HP
04/08/2009 8:48 AM
That was an order
"ANSWER ME"
only forgot to capitalise
so the answer has to be dry (with that tone it may be wet somewhere else ).
Good Answers: 101
Re: water pumps HP
04/08/2009 5:00 AM
Check the pump catalog .
Good Answers: 12
Re: water pumps HP
04/08/2009 4:37 PM
HP = ω × Q × H / 75 ×ξ
Where; ω is water density = 1000 Kg / CU meter
Q is pump discharge in Cubic meter /second
H is total head In meter
ξ is pump efficiency
example : for water pump with discharge of 60 CU. meter per hour at a total head 40 meter
ω = 1000 Kg / Cu meter
Q = 60 / 3600 =0.01667 Cu metre / second
H = 40 m
Consider pump efficiency 60 %
HP = 1000 ×0.01667 × 40 × 100 / 75 × 60 = 14.8 HP
don't tell me who are you , what do you know is enough.
DVader1000 (1); khairy Aish (1); PWSlack (2); sb (1); user-deleted-1105 (1)
