Hello all,
What would be the best choice of circuit to produce a noticeable audible detection (obvious change in pitch of a buzzer, perhaps?) of a small change in resistance, say a chage of 0.25 Ω to 0.5 Ω? The immediate application would be determination of the orecise point in rotation at which the opening of points on a magneto occurs, at which time it will not be possible to divert one's eyes from other aspects of the task of setting the ignition timing, but not all magnetos have the same primary winding resistance, so it can't be something that triggers at specific resistance value, it must detect a small change in resistance, and to be of broader use, it would be nice if it detected not only a change from zero (well you know what I mean) resistance to a small resistance, but any small change in resistance, so it could be used to spot small resistance changes in any circuit. The simple buzzer and battery used in setting points on non-magneto applications will not work, because with a magneto the points are never fully "open" because when open, because there is still connection through the primary winding, so a simple buzzer and battery never stops buzzing, and those that I've tried don't have the obvious change in pitch needed for the application. The first idea that comes to my mind is some kind of voltage divider arrangement, perhaps a Wheatstone Bridge, but it would seem some amplification would be necessary. Thanks in advance for all suggestions.
