Previous in Forum: Burning Fluorescent Tubes   Next in Forum: Solar Energy for Residential Use
3-Pole ACBs vs. 4-Pole ACBs
05/20/2009 7:38 AM
Can any one explain the difference between 3 pole & 4 pole ACB?
Good Answers: 18
Re: difference between 3 pole & 4 pole ACB
05/20/2009 7:42 AM
Four minus three is one. Sorry -- I couldn't help it.
Where did you run across a four pole ACB? I don't recall ever seeing one.
05/20/2009 9:13 AM
may be you mean 4 Pole ACB with R, S, T & N/PE Bus bar like some products from
manufacture that adopt IEC standard.
Re: 3-Pole ACBs vs. 4-Pole ACBs
05/20/2009 1:46 PM
what's an ACB?
05/20/2009 3:50 PM
In this electrical context (when describing 3 or 4 pole) it's "Air Circuit Breaker"
05/25/2009 4:24 PM
why u given answer if u dont know ACB?
this not a joke site that u come and write any thing this site is for useful for person who know more and not for u
now on words, please dont write any follies answer
05/20/2009 3:56 PM
Apart from the obvious, a 4 pole ACB would be used for special cases such as switching (or isolating) all three phases AND the neutral (where local electrical regulations require this).
05/20/2009 8:23 PM
3 pole ACB (Air Circuit Breaker) consist 3 contact point for "Red", "Yellow" and "Blue'" phase only whereas, a 4 pole ABC consist 4 contact point for "Red", "Yellow", "Blue'" and "Neutral" point.
4 Pole ACB are specially used in the generator changeover panel as we does not want to combine the neutral point of the generator with the transformer neutral point.
Both have the same operating principle.
Anonymous Poster (2); Bill (1); elect-ok (1); jack of all trades (2); Simon Wan (1)
