hi
i had to generate three phase sinewaves of 20Vrms line to line voltage, 1.5 A/phase and 500 Hz.
for this purpose, im first generating single phase from DC input. the single phase generating circuit is "LOW DISTORTION SINE WAVE OSCILLATOR" given in Application note of national semiconductors, named "EASILY TUNED SINE WAVE OSCILLATORS",linear brief 16, March 1971. i have adjusted this circuit to generate 11.5 Vrms(that is per phase voltage), 500Hz sine wave. i have taken out three parallel paths from its output. one of which is buffered using LF412A and applied to 120 dgree RC phase shifting circuit. the output of phase shifting circuit is amplified and buffered(using lf412A) and sent to push pull amplifier designed with BJTs(BD131 and BD132).
the second of the three parallel paths of sine wave generator circuit is buffered and sent to 240 degree RC phase shifting circuit. the output of this phase shifter is also amplified buffered and sent to push pull amplifier designed with BJTs. the third of the three parallel outputs of sine wave generator is buffred and sent to push pull power amplifier designed with BJT. each power amplifier will generate one phase for the three phase. the three phases are generated properly but when i attach dummy loads to the three phases(i have tested each phase with resistive loads of resistance more than the one required for my power rating having more power as well), the amplitude of the three phases is being attenuated.
suggest any solution to the problem or ammendment/ correction in the circuit
