Previous in Forum: Exhaust Gases and Air Conditioning   Next in Forum: CNC Machine
12 comments
ats schematic daigram.
05/24/2009 3:24 AM
i need some diagram for (ats) to shut off and on automaticaly generator and main power for home use.220volts and til 30 amp or above.thx
tari.
Re: ats schematic daigram.
05/24/2009 11:09 PM
Tari,
My next step would be to purchase a transfer switch. The switch will have the diagrams you are looking for. Most of them are similar, but there are different levels of "Automation" you can use with a generator and a home panel.
If it's just the diagram you seek, find a transfer switch online and download the manual... it should include the installation instructions.
Good Answers: 68
05/25/2009 12:07 PM
Hello ijmoghal,
Can you give the reason or a bit more info please? Where are you, which Country? Are you in the UK? And why would you want to have this auto-switched?
Do you mean auto-switched or auto-fused?..
bb
05/25/2009 12:45 PM
heloo mr,bb
i live in pakistan in now in our country have power problem.here are electricity are not regular fail in any time so i use now generator for backup i want that if power are fail generator are start auyomaticaly and when city power back generator shutdown auto.im electonic tech and i can assembled my self that but i have not any cschematic diagram for (AST).if you have any one please send me that.thx
best regard ifti.
05/25/2009 1:01 PM
http://www.smps.us/transferswitch.html
Diagram may vary by Country....
Good Answers: 68
05/25/2009 1:13 PM
Hello ijmoghal,
Try this site as well.
http://www.electronicsinfoline.com/?gclid=CMfbg9H615oCFZ4U4wodR2P33Q
They have jifs of all kinds of schematics. So I would think you could find what you want here.
bb
Good Answers: 68
05/25/2009 1:49 PM
Hello ijmoghal,
These sites will help you I think.
http://www.google.com/search?client=safari&rls=en-us&q=schematic+for+switch+to+turn+generator+on+and+off+automatically+220volts+and+til+30+amp&ie=UTF-8&oe=UTF-8
Good Answers: 39
05/25/2009 7:30 PM
Baby Bear, I am having trouble geting Google to produce results. I cut and pasted the entire string but keep getting a "no results found" to my search query.
to the original poster:
As for the automatic transfer switch the schematics I did find all lack a critical element. They do not show the circuitry associated with the coil of the transfer switch and they do not show how the generator is actually started.
This is important. The simplest approach is to use a double throw relay or contactor with a coil rated for the mains voltage. Hwever depending on your local utility power authority, additional safety features may be required. For loads of less than 30A arc quenching may not be so difficult to achieve. But not all relays are equally suited because they lack the required snap action to quickly extinguish the arc created by load break. A motor start contactor is better suited since it is by design intended to open the on load contacts at full rated amps. In my own experience the contacts must move at least 6 mm and do so quickly in something like 16 - 20 milliscond.
If you intend to build this from scratch I suggest you include a flyback diode to prevent back EMF since part of your house loads will most likely include inductive motor loads.
If you choose to drive the relay coil direct from mains, when the mains voltage disappears, the relay or contactor drops out and this in turn connects the load to the generator. Simple and nearly fool proof. BUT, . . how to start the generator automatically is the big question. Many products advertising an Auto start feature only provide a dry contact for signalling the generator start. a seperate controller board supplied by the genset maker is required.
Many of the home type generators of less than 10 kW do not have any sophistication in the start circuit. They rely on the operator to manually toggle the start switch. Feed-back as to when to stop pressing the start switch is a matter of the operator hearing the motor actually running. If the motor has a low oil pressure switch ( safety) then a bypass circuit must be provided. Otherwisse it will never start. If a diesel engine; a glow plug timer circuit must also be included.
Secondly; a cranking limiter circuit must also be provided. Otherwise how does it know when to release the momentary start button. Failure to release the cranking circuit wil damage the starter motor. If the genset is not air cooled, you need additional bypass circuits for the various alarms assocuiated with the liquid cooling circuit. This dependent on the model of generator provided. these timer functions could get expensive. you can use either individual timer relays or a more sophisticated PLC. These are available for under $100 USD.
In off-grid applications and larger yachts I specify use a controller board designed to work with many of the brand name generators. Being a North American product I doubt it would be availabel in Pakistan. Try siemens or ABB for somethign appropriate locally. It provides the necessary bypass circuits timers and cranking limiters needed to safely start gensets automatically.
I have a chinese copy of a Yanmar engine for my own installation and am doing exactly the same thing as you are trying to do. Unfortunately the Yanmar is so basic it means a lot of extra work to set it up for automatic operation. Still tinkering.
The commercial board cost USD $560 and involves a couple of hours to install.
Since you are an electronics tech it should not be any problem to figure out something yourself using what is actually available to you locally in Pakistan. But it could get expensive. Not much point in using a schematic calling for parts that you cannot get easily or at low cost.
If cost is not an issue why not just buy a commercially made transfer switch. It certainly would be easier.
Elnav
Good Answers: 68
05/26/2009 8:32 AM
Hello elnav,
try typing just the address as below:
If you like the site search for others like it or for whatever specific transistors etc you need. I assume you kind of have a design in your mind?
Sounds like an interesting project, keep in touch please?
Take care and let me know if shortening the address to the sites name works for you.
bb
Good Answers: 39
05/26/2009 1:13 PM
Thanks! That shorter link worked.
elnav
Elnav
05/26/2009 3:38 PM
dear elnav,
i try many website but not found any cschematic diagram for auto changer switch (ats) i am in pakistan and here are price of a switch are very coastly for me.so i can assambled my self just need diagram.thx
tari
Good Answers: 39
05/26/2009 3:57 PM
Tari read my earlier post.
A simple auto change switch can be made by using a double pole, double throw relay or contactor with a coil voltage same as your mains. The contacts must be rated to carry the whole amount of current you expect to pass through.
The coil is wired to your mains supply. The mains are also wired to one side and your load is connected to the common terminals. When the relay is not energized one set of contacts is called Normally Open, (NO) the other side is called Normally closed (NC)
Your generator is wired to the NC contacts and the mains from utility is wired to the NO contact. The coil is also wired to mains.
With mains voltage present, the relay closes the NO path and the power passes to your house by way of the common contacts.
If the mains are interrupted, the relay drops out and now your genset is connected to your house.
BUT! . . . you still need a way to automatically start the genset. Or do you just want to go and start it manually?
In my earlier post I explained what was involved in an auto start module for any genset. Read it again.
I am not sure how to make it any simpler for you. One relay and six power wire connections, plus the coil connection.
This is how thousands of inverter / chargers work.
Elnav
07/09/2009 2:30 PM
That was some help.... You seem to be a real good guy. Dont let the help work die... fastxs@gmail.com
Register to Reply 12 comments
Anonymous Poster (1); babybear (4); elnav (3); ijmoghal (2); mlimberg (2)
