Previous in Forum: Simple Fiber System   Next in Forum: reverse power in powerplants
Ferrous and Non-Ferrous Materials
06/01/2009 10:36 AM
I have seen 15kv switchgear that specifice the bottom cable entry plate has to be non-ferrous material. Means Aluminum can be used for this application as Aluminum is a non-ferrous material, but stainless steel can not be used. My question is how is the Ferromagnetism action on ferrous materials is a concern in this application. Since Aluminum is a conductive material, how it suits for this application. I thought all conductive materials have to have a magnetic action as electro magnetic force has to develop to conduct electricity.
Good Answers: 53
Re: Ferrous and non-ferrous materials
06/01/2009 11:16 AM
There are ferrous metals (stainless steels) which are non magnetic. So I doubt it has to do anything with magnetism.
Re: Ferrous and Non-Ferrous Materials
06/01/2009 9:27 PM
All the high voltage switchgears bottom cable entry plate includuing transformer primary and secondary bottom cable entry plate, has to be non ferrous material as to eliminate the induction of the magnetic field by the power cables. Commonly, most of the cable used for the high voltage switchgears is by single core cables.
If the bottom plate of the cable entry is made from ferrous material, Ferromagnetism action on the ferrous materials will occur. Cable that carried an electric current produces a magnetic field. The magnetic field a pattern of circular field lines surrounding the wire. When Ferromagnetism occurs at the bottom entry plate, there will be some heat generated and in some cases the bottom entry plate can vibrate.
Even Aluminum is a good conductive material, just like the copper, but both of these material is non ferrous material and both of them does not induce ferromagnetism. Likewise, other material such as stainless steel, alloy and brass.
06/02/2009 11:15 AM
Thank you for a good answer, few words but means a lot
Anonymous Poster (1); rakesh_semwal (1); Simon Wan (1)
