i have created a lenz turbine
i am still making the generator but i wanted to know how much wind swept area i have so i know what to expect for out put
you can see some of the 3-d models here http://thewindpowercorp.com/
please no comments on how the web site is not finished yet i know, i know
design is going into its paten pending status all work copyright property of wind power inc Miami fl
the size of the turbine is this
length of each sail from top to bottom is 9 feet 6 inches
distance from center or radius of turning circle is 3 feet or 36 inches
using the lenz formula found online the total width of the sails is 28 inches
the radius diameter of the curve in the sail is 11 inches
the offset is 9 degrees
each individual sail has almost 20 square feet of canvas so do i count all (3 per turbine)the sails or just one
i don't know/cant find the formula or method for the wind swept area of a / for a lenz turbine
i have two of these turning one generator so what is my peak out put possible at 10,20, and 30 mph wind speed?
