How much contamination or particles are generated when a blower is pushing air thru aluminum components?
I have a 3HP blower generating about 100 cfm thru two air knives. It's low pressure. 3-5 psi. I have a choice between stainless steel, and aluminum. I understand that the air passing thru the stainless steel air knives will be purer. But I'd like to get a better understanding of what kind of contaminants would be generated if I use the aluminum. I've heard that aluminum is considered a "dirty" metal. But not exactly sure what that means. Is there oil on the aluminum? Is it the porosity of the aluminum that causes this? The manufacturing process? Is it aluminum particulates that cause the dirtyness? Just plain dirt and dust that is embedded?
Can someone shed some light on this for me?
