my question is. i recently took 2 tests with 1 3/8" 304 stainless plate with an 1/16 landing to a carbon plate the same specs, butted together with no backing plate (easy i thought) 1 procsess was mig the root looked great so did the rest of the weld. im not sure of wire diameter but it was what the company uses every day. i have years of exp. after welding the beveled side they told me to flip it and grind out the seam on the back and fill that in. i thought how can i fail> i did the same with tig procsess. all they did to test them was a bend test.my welds looked great no under cut or problems in visual. but when they bent them i failed. my question ? is do i need to consentrate my heat on one side or the other probably the stainless is my guess but the company is gonna give me another shot. so i beg for help i need the work. can you tell me why those bends failed. ive welded stainless to carbon 100's of times but i failed both procsesses. i beg for help. p.s im not a rooky welder ive been in the strucural an high purity stainless trade for 14 years. and all my wire was correct to the company specs. thank you and please help i beg. you know how the job market is. what do i do to make my bends not break. everything was great when i left i thought no problem but im missing something. PLEASE HELP ME .
