Previous in Forum: shelf life under ground water tank   Next in Forum: Acid etching.
16 comments
water falling
06/26/2009 11:46 PM
I have water falling from a eight inch pvc pipe twenty feet high into a tank. i want the volume to stay the same but reduce the velocity as it is falling to stop the turbulance in the tank. any suggestions. thanks
Re: water falling
06/27/2009 12:11 AM
Hello Guest,
Extend the PVC pipe down to below the surface of the water in the tank. If you can't do that, get it as close as you can to the water surface in the tank.
Mike
Good Answers: 103
Re: water falling
06/27/2009 12:11 AM
Bring the pipe down to water level. Then put some large baffle in the bottom to reduce the velocity so that the turbulence stays inside the smaller tank (at the end of pipeline)
Re: water falling
06/27/2009 10:56 AM
Lower the pipe a bit and angle it so that the water is flowing parallel to the side of the tank. This will cause a slight whirlpool effect which can be deflected or reduced by baffles.
CARPE CRUSTULORUM!
Re: water falling
06/28/2009 8:59 AM
If your problem is agitating the tank water place a 90 degree elbow at exit of water pipe so water turbulence is at top of tank only. You could also install a diffuser that spreads the exit water over a larger area to cut down on turbulence. Since I am not 100% certain of your particular system this is just a few suggestions.
Re: water falling
06/28/2009 9:14 AM
Is there some way you can direct the water to the inner surface of the side of the tank, so that it runs down the wall into the volume of water instead of dropping in?
They say time changes things, but you actually have to change them yourself. ~Andy Warhol
Re: water falling
06/28/2009 9:38 AM
It sounds like the current exit is 20 feet above the tank - if that's so - you could hang a plastic link chain from the current exit so that it dangles in the tank - the water velocity will reduce because it will have to work its way down the chain to reach the tank instead of just falling straight in.
To secure the chain to the current exit, tie a knot in the top end of the chain so that the knot is big enough to jam in the downpipe diameter.
The bigger the chain, ie, the more surface area of the chain, the more volume it will handle.
I presume that you're doing it to stop the falling water splashing outside the tank when the fall is heavy, and for some reason you don't want to extend the pipe, is that right?
Some Japanese houses have such chains instead of downpipes because the Japanese like the appearance of falling water. Usually they can be steel but that requires a good strong fixing and I assume you just have a plastic downpipe, and if that's so, then a steel chain would be inappropriate in your case.
Reply Good Answer (Score 4)
Re: water falling
06/28/2009 10:38 AM
Tie a string to the pipe, water will run down the string, and just about eliminate the turbulence.
Don't over complicate things, simplicity is the key to good solutions.
Hobbies - Fishing -
Re: water falling
06/28/2009 11:02 AM
Connect a hydro-electric unit to the end of your penstock. Almost all the velocity will go into turning the turbine and your volume won't change plus you'll have electricity.
“Sometimes I wonder whether the world is being run by smart people who are putting us on or by imbeciles who really mean it.” -Mark Twain
Good Answers: 196
Re: water falling
06/28/2009 11:15 AM
Let's look at the basics here --
Your problem is that there is unwanted mechanical energy, both velocity energy potential energy in the inflow liquid. You would like to disipate that energy into internal energy before it reaches the main body of water in the tank to disipate via the unwanted turbulence.
The other issue is exactly what kind of turbulence in the tank is unacceptable? Is the problem large volume turbulence from a single stream falling directly into the water? Or is part of the problem surface splashing from water splashing off the tank walls from a high velocity inflow? You didn't mention the flow rate(s) through the 8 inch line.
Note here that a steady inflow "rain" of water falling uniformly on the surface would produce primarily surface turbulence. A nozzle or distribution system (maybe too complex) would disipate much of the velocity energy and to the extent that it flowed down the walls of the tank would romove a big part of the potential energy.
If none of the easy suggestions already mentioned work well consider this:
Assuming the tank has a watertight sturdy roof a fabricated outlet structure with upward facing nozzles directing "jets" or baffles pointed at the area of the tank roof as well as the upper sides. Don't forget "doors on the sides or bottom to facilitate maintenance. This is the kind of thing that could be easily fabricated from steel or stainless steel or even a fiberglass/epoxy structure with construction like a small boat and attached to or suspended from the roof with a connection to the inflow pipe. The idea is to get a "rain effect" distributed over as much an area of the tank as possible.
Ed Weldon
Re: water falling
06/28/2009 12:10 PM
well Quantity of water is proprotional to area and velocityi.e.
Q= A* V
Q= volume of water
A= Area of pipe
V= Velocity of water
Now to change the velocity without changing the quantity increase the diameter of pipe
waterparks
Re: water falling
06/28/2009 2:10 PM
A stout canvas bag tied to the end of the tube will work. bioramani
bioramani
Re: water falling
06/28/2009 10:01 PM
Another option is to install a splash plate for the water to hit after it falls. This would change a steady stream of water into a bunch of distributed droplets. That will tend to prevent the turbulance you wish to avoid.
Re: water falling
06/28/2009 10:15 PM
Put a 180 degree (2-90 degree) elbow and about 3 or 4 feet of pipe so that the top of the "return" pipe is the same as the normal high water level. You could also serpentine the flow using a series of elbows to dissipate the kenetic energy.
Re: water falling
06/29/2009 5:06 AM
I solved a similar problem but on a smaller scale but putting a piece of foam rubber where the water entered. I got the idea from a local theme park,, where 'slugs' of water are fired in an arc over peoples heads, to dissappear into the ground without a splash. It was a very open mesh lattice type foam rubber on the landing area.
It may not work for you to have foam in the water, but a mesh lattice, layer on layer, may do the trick. It could float on a dingy, only anchored to the sides or bottom.
Jim
Good Answers: 42
Re: water falling
06/29/2009 10:09 AM
GUEST,
Your post had fetched many a solutions unique and interesting. Let me add my solution too.
What you can do is to keep a 50 litres or 100 liters bottom closed and top open container properly grounded in the tank with suitable support frames and stone weights.. The open bottom pipe end will deliver water at higher velocity into the container and get over flown through the upper walls sides and fill the tank with reduced turbulance.
Nature is so graceful and naked. Human possession is ridiculous.
Re: water falling
07/29/2009 12:34 PM
tie a piece of string from the pipe to the tank then the water will fall down the string and not through free air this will reduce the turbulance in the tank
Reply to Forum Thread 16 comments
Anonymous Poster (3); bioramani (1); cnc jim (1); CurieFury (1); Ed Weldon (1); lighthasmass (1); Mikerho (1); not so smart (1); roy hammy (1); s.udhayamarthandan (1); sb (1); Slowpoke (1); Stecool (1); waterparks (1)
