Previous in Forum: BS 853 Equivalent DIN standard   Next in Forum: Evaporator Coil design for an Ice Bank - Help in size up
8 comments
Conversion
06/27/2009 5:47 AM
We need Nm3 to m3 conversion for 10 Nm3/Min, Pressure 2.1 bar.
Barometric pressure is 98 Kpa
Temperature Minimum:20 deg. C, maximum:44 deg.C
Medium: Compressor air
Good Answers: 103
Re: Conversion
06/27/2009 6:03 AM
Please check earlier threads
http://cr4.globalspec.com/thread/25018
And the interesting part is the title of the thread is
Nm3/hr to M3/hr
A normal google search too would have landed you into this as well as a few others.
Re: Conversion
06/27/2009 6:43 AM
We were not able to understand the search results in google. If you know please give details with basis of calculation
Good Answers: 103
Re: Conversion
06/27/2009 9:22 AM
The gas equations are
PV = nzRT
or PV/nzT = R = Const.
So
P1V1/ n1z1T1 = P2V2/ n2z2T2
or
PactVact/ nactzactTact = PnVn/ nnznTn
n = number of moles and z is the compressibility factor.
or
Vact= PnVnnactzactTact / nnznTnPact
Vact = (nact/nn) (zact/ zn) (Pn/ Pact) (Tact/Tn) Vn
or if yoy want to talk in terms of Volume, convert the V (volume) into Q (Volume Flow rate) and then
Qact = (nact/nn) (zact/ zn) (Pn/ Pact) (Tact/Tn) Qn
For the lower pressure and temperature range, for air, we can safely take
zact= zn and nact = nn
so we have almost the ideal gas equation
Qact = (Pn/ Pact) (Tact/Tn) Qn
Pn = 1 bar = 101.3 Kpa
Tn = 20 deg C = 293 Deg K
Qact = (1/ Pact) (Tact/293) Qn
here Pact = 210 +101.3 = 311.3 Kpa
Tact = 293 - 317 Deg K
so
Qact (m3/hr) = (101.3/ 311.3) (293~317/293) Qn (Nm3/Hr)
= 0.3520 Qn
or Qn = 2.84~3.07 Qact
(Hope my calculations are correct )
Re: Conversion
06/29/2009 7:40 AM
Dear Guru,
Thank you for your detailed calculation.
If we are converting from 10 Nm3 to Am3= 3.6 Am3 is coming, for 10 Nm3 to Sm3= 11.57 Sm3 is coming as per our temperature and pressure conditions. So what we have to consider,Am3 or Sm3 ?.
Good Answers: 103
Re: Conversion
06/29/2009 8:22 AM
The capacity of the compressor (cfm or m3/Hr) if I am not wrong are expressed as
The amount of Air or gas the compressor can compressed at one atmosphere sea level, and 20 deg C
This almost fall in the STP region and not NTP region.
Check this link where different rating types are provided.
http://www.engineeringtoolbox.com/rating-air-compressors-d_848.html
Re: Conversion
08/19/2010 4:36 AM
Dear Sir,
I tried calculating your way but my answer comes negative.......if you can please check
Qact (m3/hr) = (101.3/311.3) (293-317/293) Qn (Nm3/hr)
i get
Qact = -0.0267 Qn
Can you please check and correct me if am wrong.
Nothing is impossible, even impossible says I M Possible
Re: Conversion
06/29/2009 2:28 AM
Your need of conversion can be due to following factors.
1. You are considering procuring compressed air system. or
2. You are an young engineer would like to learn the design procedure. Or
3. You are an Owner ( Non Technical ) and has to give your approval. Or
4. You are an approving authority and does not trust your Team design work.
Can you throw more light from above so that we understand your need.
Re: Conversion
06/29/2009 7:45 AM
We are planning to procure compressor and want to know technical details
Anonymous Poster (4); santy1980 (1); sb (3)
