Previous in Forum: World wide Vendor of solenoide valve & switch   Next in Forum: Audible Alerts
Torque Rheometer
07/15/2009 10:06 AM
Using a Brabender plasti-corder with a 3 piece mixer. Anyone out there using similar equipment? Need to know if all 3 zones on the 3 zone electric heater should heat, right now only one is doing the heatinf, the others are following from conduction. Checked fuses, checked thermocoples, reprogrammed controller, should I check the heaters?
Re: Torque Rheometer
07/15/2009 1:21 PM
nvm, got it
07/16/2009 10:11 AM
It depend of what you want to do with it. Are you intending to mix polymers, to add solid charges in polymers? Are you using it as a rheometer, to measure the flowing properties of your material, or as a mixer?
If you want to do precise measurement of the torque vs RPM (and temperature) you need that the heating of the 3 zone work properly because you may have thermal gradient in your sample.
But if you are using the instrument only for mixing (or if you don't need very accurate measurements) it could probably do the job with only the middle zone heating. The viscous heating of your material will help to uniformize the temperature as well as the forced convection of the mixing.
You might be interested in: Fuses, Feed Screws and Mixer Screws, RF Mixers
