Previous in Forum: Tow Tractor   Next in Forum: Disposal Standard
25 comments
Good Answers: 74
Machining Perspex
07/15/2009 9:09 PM
Dear CR4rers
I am having difficulty getting meaningful information about one off perspex designs I have come up with.
I have included a picture of what the end result could look like. It was made by hand using a router (and tricks) and is more of a sculpture than a machined piece of perspex. Some friends have shown interest in having one but it would take too long to make, meaning the price would be more in the range sculpture.
There are no screws or glues and only the seat is shaped over a hot mold.
I have done some search about water jet and laser cutting but the information I can extract is not hands on enough for me to appreciate. They all seem like winners and I can't just go and visit their set up.
I have also considered poring epoxy in to molds but that would limit design variations and it would make more work than needed and make it mass production which I do not plan.
I have made a few versions over the years and they are designed with minimum waste of material. The off cuts become the counter piece or parts of the next version, if you like.
I have only hand drawings but could create CNC readable files if needed.
My question is: can some one make suggestions on how to proceed most efficiently, by choosing the best cutting, milling or any other method I have not come across yet?
The perspex or other similar materials would be around 10mm thick and all (or most) off cuts should stay in one piece. The parts have to be flat and not warped and be within 0.5mm tolerance.
I can not set up a work shop for this at home so I will have to out source this, if at all feasible. It really looks like a get poor quick exercise at the moment.
Ah, what the heck, here is another one.
I would appreciate any suggestions. Thank you, Ky.
The Twain Has Met
Pathfinder Tags: Laser machining perspex water jet
Engineering Fields - Electromechanical Engineering - Graduate Mechatronic engineer Engineering Fields - Control Engineering - Enthusiast
Re: Machining Perspex
07/15/2009 10:37 PM
Hey Ky!
Your designs look absolutely brilliant. Very aesthetically pleasing. Given your specs (10mm thick and 0.5 mm tolerance), I'd say water-cutting for the planar shapes is your best bet - its usually prefered over laser cutting when the material thickness exceeds around 6 mm. This process can be expensive - its great that you've designed for minimum wastage - keep in mind the standard sizes of material that your manufacturer can order too (e.g. for Aluminium sheet, 601x1201mm is the worst size for a plate you can order, as they mostly come with dimensions of integer multiples of 600mm). Most places in Aus prefer A0 sized DXF. files to cut from -I've found that If you arrange as many cut-outs as possible on the same drawing sheet, it seems to be cheaper per part! (dunno why... must be psychological). As far as your molded pieces go, I'm not really one to give advice - all I can say is that when I've done epoxy resin molding before, I've had considerable trouble with CO2 and other gases being released gradually after you mix in the hardener, often leaving bubbles trapped in finished piece (even if you're vacuum forming) which I think you'd want to avoid, given that its appearance important. There are ways to prevent this, but the curing time takes yonks.
Hope that helps
TinTin
Good Answers: 74
07/15/2009 11:23 PM
Thank you Tin Tin
That was the basis of my concept, to cut once and create 2 pieces and have only the "saw dust" as waste or molecules of perspex, if water jet is used. All designs are based on standard sheet sizes for perspex. They hardly differ from other standard sheet sizes. It would be fun to make one version from aluminum but that would hit the back pocket even harder, I suspect.
I have contacted some companies who have the tools/technology you mention but had no reply. One offs don't seem to fit their profile but more repetitive stuff. If I would order 50 tables and 200 chairs and give them a deposit I'm sure one would be able to do business. Just the materials for a set would be around $600 plus freight and machining. Wanting only one or three reduces their interest in a project like this considerably, which is understandable.
Thanks again and see what else comes up. Just wetting a line really, Ky.
The Twain Has Met
Good Answers: 74
07/15/2009 11:32 PM
I forgot to mention that all edges (except the fits, were the parts meet) would have to be rounded or at least beveled. Ah, and I'm happy you like them, Ky.
The Twain Has Met
07/15/2009 11:45 PM
No worries Ky - I'm sure a lot of people will like them! They almost look like ice sculptures, very cool ...er... pardon the pun. Given the low quantities and finishing required, you could produce them yourself like you did with those prototypes. While it might not be the most desirable option, I'm sure you'll get a lot of satisfaction from making them. Do you know what sort of price people are willing to pay for them? Perhaps the percieved cost of outsourcing their manufacture is actually worth it - there'd be some chique bars and cafe's in melbourne and sydney that'd go for this sort of thing, aside from collectors and art lovers.
Good Answers: 74
07/16/2009 12:12 AM
Hi Tin Tin
Just the amount of shavings from one table could make a nice front yard Xmas display if I use the router. And then the noise it makes, not to mention the smells when things get too hot and they do, even when using lubricants of what ever kind. Detergent and grape seed oil emulsion have worked great but it is still a very tricky operation. Every time I start on one, my neighbors know that it will be noisy for a while and I want to avoid that in the future. Sanding, polishing and flaming the edges for clear versions is the least of my problems.
Because the prices have to be in the realm of sculpture, if I make them by hand, I want to find a less costly and less annoying way of having them made. Thanks for your in put, I appreciate it, Ky.
The Twain Has Met
07/17/2009 1:44 AM
Good idea...bad idea.
Let me explain...great design, looks real great. Personally I would not have put up pictures of the finished product. You have given the idea to someone else who is probably already got their machines cutting in some cheap labour country. I hope I'm wrong for your sake.
All the best...sorry i don't have experience in plastics.
Have you worked for IKEA before?
Good Answers: 74
07/17/2009 2:46 AM
Thank you guest
That is very considerate of you to be concerned about copy cats. Like I mentioned, I have a few more designs up my sleeve and am not worried. There are a few other things to consider making this design workable and they are not shown in detail.
Just showing it here on CR4 makes any copy cats impotent. Its better and cheaper this way (excluding IP professionals) and I fear no competition. If they start up mass production, who cares? It is the art that counts and it is mine and that is good enough for me.
I appreciate your concern and can not reveal the real issue or advantage with these tables. They have a twist and that twist is still with me. Let them do it and they will see, that negotiating with me, would have been a much smarter move than to try and rip me off. They are able to pinch the song but not the singer, if you know what I mean.
And, no, I have not worked for them (Ikea) before but if they would ask I would consider showing all, including the twist which has not been published. I will keep that close to me chest.
Thanks again, take care, Ky.
The Twain Has Met
United Kingdom - Member - New Member Engineering Fields - Transportation Engineering - New Member Technical Fields - Marketing/Advertising - New Member Hobbies - Target Shooting - New Member
07/17/2009 5:42 AM
We make small custom perspex panels (approx 220mm x 130mm) for loudspeakers and other associated electronics using a small CNC miller. Bevels and radiused edges can formed. Our miller is quite slow and it may not be possible to speed up much without melting the perspex. We use one run with an ordinary drill bit to remove most of the material quickly and then another run with a milling bit to clean up and do any profiling. This approach would certainly be able to cut out the parts, but it may not be possible to speed it up enough to make furniture sized parts.
Good Answers: 74
07/17/2009 6:31 AM
Hi Chankley
Yeah, it always seems to be a trade off and short cuts seem to be as rare as hens teeth. Its been bugging me since a while now but I'm sure there are some that have more expieriance with the matter than I have. Pre drilling is some thing I have not thought of so thank you for your tip, Ky.
The Twain Has Met
Good Answers: 15
07/17/2009 6:56 AM
I could make the first design in my wood shop easy enough. I even have a set of plans for a table that looks very similar to your first picture. The legs are slotted so it can come apart far storage or to make it somewhat portable.
I don't know anything about perspex though. Have you looked in purchasing a CNC machine of your own. They make smaller less industrial sized ones far home shops. They'll handle regular size 4'x8' sheets of materials and come with the software to do the layout with as little waste as possible. I've even considered buying one. I can't think of the particular name of the one I would like to save my $ far.
Here are examples of what I'm talking about.
http://www.torchmate.com/catalog/catalog/index.htm
http://www.epiloglaser.com/
scotchdrnkr
Good Answers: 74
07/17/2009 7:46 AM
It really looks like a get poor quick exercise at the moment. (from original post)
I know. The examples you are suggesting will not tolerate my surroundings, not allow for even light industrial. Perspex is a hard to handle material and does not give up that easy, if you want it to do what you want it to do. I am sure it would be achievable if I had a fully equipped work shop but my location puts a brake on matters. Besides, I am just trying to over come the odds, from were I am. Thank you for your suggestions, I'll have a scotch on you, for the moment being, thanks, Ky.
The Twain Has Met
07/18/2009 6:01 PM
I have been ordering custom parts, and the general rule is that the first is most expensive as that is where all the set-up costs go. I asked for prices for 1-off and 5-off: £165 each single, £45 each for 5. No doubt 1000 would cost about the same as the raw material!
Madness is all in the mind
Good Answers: 68
07/18/2009 11:11 PM
Hello Ky,
I really love your furniture!
I think clear or translucent furniture is unusual and makes a room look bigger?
Find below, in order of Country::
Australia
USA
UK
Keep in touch and all the luck in the world with your venture!
=================================================== AUSTRALIA
Results 1 - 10 of about 26,500 for machining perpex in australia. (0.23 seconds) THE DUCTILE-BRITTLE TRANSITION WHEN MACHINING PERSPEX undesirable phenomenon also occurs when machining perspex at heavy feed rates, ... Proc. of Tewkesbury Conf. on Fracture, Melbourne, Australia (August). ... www.informaworld.com/index/773187886.pdf
Similar -
by RF Scrutton - 1965 Hamilton Australia, Fume Cupboards, Fume Extraction, Perspex - Home Signs, Letters and Numbers any machining parts in all types of plastics. ... 2009 Hamilton Australia, Fume Cupboards, Fume Extraction, Perspex. www.hamiltonaustralia.com.au/
Cached - Similar -
Plastics Acrylic Perspex Fabrication Fabricators Perth WA ... Plastics Acrylic Perspex Fabrication Fabricators Perth WA Australia Midland ... cutting phenolic injection moulding machining plastics plexiglass inc suntuf ... www.cplastix.iinet.net.au/
Cached - Similar -
H10347 Harvesting machine and guard, 'Sunshine' Stripper Harvester ... H10347 Harvesting machine and guard, 'Sunshine' Stripper Harvester, metal / perspex, HV McKay Harvester Works, Victoria, Australia. www.powerhousemuseum.com/collection/database/?irn...
Cached - Similar -
PROCON TECHNOLOGY - Mini lathes & milling machines from $495 Danny, Australia. 'I purchased from you a C3 mini lathe a year or so ago - still ..... Supplied with perspex chip guard. These milling table slides use ... users.tpg.com.au/users/p8king/tl4000.htm
Cached - Similar -
Perspex Ltd. is one of Australia's largest stockist and distributors of ... Machine Guards; -; Plastic Fabrication; -; Brochure Holders; -; Engineering Plastics ... www.hotfrog.com.au/Products/Perspex
Cached - Similar -
perspex Miscellaneous | Find the Best Deals on Miscellaneous items ... Shop the Miscellaneous category at Shopping.com Australia. ... at eBay Australia . See It. Tattoo Machine Holder Perspex 25mm Featured Item ... au.shopping.com/xDN-miscellaneous-perspex
Cached - Similar -
Allplastics Engineering: Precision Plastics Machining The services offered by Allplastics include precision machining of ... the widest range of services and materials in the plastics industry in Australia. ... Traditionally used in for illumination and light box creation, Perspex™ Opal is ... www.industrysearch.com.au/Suppliers/Allplastics_Engineering
Cached - Similar -
AB Plastics Australia Pty Ltd - Acrylics, Polcarbonate, Perspex ... For Polycarbonate, Acrylics and other Plastics, AB Plastics can help. www.abplastics.com.au/products/machineguards.php
Cached - Similar -
Allplastics Plastics Engineering Sydney NSW AUSTRALIA ACRYLIC. ENCAPSULATION. Perspex ®. FABRICATION. Qualified and Experienced Tradesmen. Advisory Service for all your needs. PRECISION MACHINING. www.allplastics.com.au/machining.htm
Cached - Similar -
==================================================== USA
International Trading Partners, Ltd. - Multiwall Polycarbonate ... With the AntiDUST Multiwall Cutter the polycarbonate sheets no longer have to be blown ... sheets are no longer cut with noisy power tools but with an efficient blade cutting machine. ... USA (410) 757-5040 [Voice] (410) 757-1821 [FAX] www.itpsales.com/cutter.htm
Cached - Similar -
Polycarbonate Squares: CS Hyde Co, IL, USA Polycarbonate squares have extreme impact strength, high modulus of elasticity. Used in Sight glasses, manifolds, insulators, diaphragms & other machined ... www.cshyde.com/Moreproducts/polycarbonate.htm
Cached - Similar -
SAN DIEGO PLASTICS, INC. - POLYCARBONATE PLASTIC Polycarbonate can be machined on standard metalworking or woodworking equipment ... is approved for contact with wet and dry food applications and meets US. ... www.sdplastics.com/polycarb.html
Cached - Similar -
Online Sourcing the Machining of polycarbonate rack by an ... successfully sourced for the Machining of a part called polycarbonate rack on www.MFG.com ... 2700 Cumberland Parkway, Suite 500. Atlanta, GA 30339 USA.
www.mfg.com/.../Machining-61546-Columbia-Missouri-United-States.html
Cached - Similar -
Online Sourcing the CNC Machining of Spacer, Polycarbonate by an ... Get quotes online for precision machining, milling, turning, Swiss Machining and wire EDM ... 2700 Cumberland Parkway, Suite 500. Atlanta, GA 30339 USA. www.mfg.com/.../CNC-Machining-216972-Neenah-Wisconsin-United-States. html
Cached - Similar -
Polycarbonate Gluing On GlobalSpec Browse Terminal and Junction Boxes Datasheets for FIBOX Enclosures USA ... Lenses Polycarbonate Tubing Polycarbonate Labels Polycarbonate Machining ... materials.globalspec.com/Industrial.../polycarbonate_gluing
Cached - Similar -
Plastics: surface and finish - Google Books Result by W. G. Simpson, Royal Society of Chemistry ... - 1995 - Technology & Engineering - 327 pages
(v) Blends of ABS and Polycarbonate Over recent years the range of materials ... closer in weight and in 'feel' to components cast or machined from metal. ... books.google.com/books?isbn=0854045163... -
United Machine and Tool - Illinois (IL) - USA ... Iron Castings, Vertical Machining Centers, Polycarbonate (24936-68-3), ... Click the links below to visit our website or contact us via our profile ... www.kellysearch.com/us-company-900036160.html
Cached - Similar -
Clear Polycarbonate in US. ... Acetal Rods, Acetal Sheets, Acetal, Acrylic Machining or Casting or Engineering, Acrylic, Plastic Prototype Adapters. ... chemicals.zibb.com/suppliers/clear+polycarbonate/us/25880900
Similar -
<B><Font face color=NAVY>Polycarbonates</B></font face>: Plastic ...
Gallina USA LLC offers polycarbonate multiwall sheets and systems. ... Quadrant Engineering Plastic Products offers PC 1000 machine grade polycarbonate, ...
www.plasticsmag.com/ta.asp?aid=4076
Cached - Similar -
Sponsored Results Polycarbonate Film&Sheet. US Mar Resistent PC Manufacturer Uncoated PC Sheet, PC film, FRPP Polycarbonate Machining Grade USA TODAY® STORE · NEWSPAPER DISTRIBUTION PRODUCTS ... Hydex 4301 - general purpose machine grade polycarbonate. It comes in natural and black. ... www.worldofplastics.net/polycarbonate_machining.htm
Cached - Similar -
A 96-WELL SPRI REACTOR IN A PHOTO-ACTIVATED POLYCARBONATE (PPC ... 150200 µm thick SU-8 was machined down to the thickness of 50 µm by flycutting ( Optimum 120,. Precitech Inc., Keene, NH, USA) to obtain a total ... ieeexplore.ieee.org/iel5/4432954/4432955/04432983.pdf?...
Similar -
by DS Park - 2007 - Related articles Polycarbonate Safety Glasses USA is a factory authorized distributor of safety glasses and ... ADISCO, Inc - Precision CNC Machining of Plastics is our specialty to a ... www.hotfrog.com/Products/Polycarbonate
Cached - Similar -
==================================================== UK
Results 1 - 10 of about 16,800 for machining perspex.
Glass Micromachining Devices, holes, flexures, etc. Fabricated to your specifications.
www.translume.com
Perfection in Plastics We are the perfect choice for your perfect product www.tefloturn.co.uk
England Lawday Engineering Ltd Prototypes Tool Design Manufacture & Machining ISO9001 Quality Assured www.lawday.co.uk
Plastic Machining Service www.apt123.co.uk
We mill, rout, laser cut, bend and fabricate plastic components Machining Acrylic Pentaprecision.co.uk/acrylic
ISO:9001 Acrylic Machining Experts Competitive, Responsive Service Search Results Perspex Sheet - Workshop Manual "Working with Perspex" The machining characteristics of Perspex from Lucite are similar to those of soft ... diamond-tipped tools are particularly suitable for machining Perspex. ...
www.theplasticshop.co.uk/.../working_with_perspex_manual.pdf
Similar - Perspex - Machining Perspex Machining. ... Perspex - Machining. Index of companies supplying: Perspex - Machining. Abplas Ltd - London; Acrylux (SW) Ltd - Tiverton ... www.applegate.co.uk/products/00/95/479.htm
Cached - Similar - Carville Ltd, Plastic Machined Components, Acrylic Machining Established in 1928, Carville have over 80 years of experience in the manufacture of precision plastic machined components in PERSPEX Acrylic and other ... www.applegate.co.uk/company/00/15/340.htm
Cached - Similar - More results from www.applegate.co.uk
» acrylic drilling
A spindle moulder is a useful machine for the rapid machining of Perspex®. Cutters designed for woodworking are suitable, two-bladed cutters being preferred ... www.ultimatehandyman.co.uk/ACRYLIC_DRILLING_MACHINING.htm
Cached - Similar -
Plastic Sheets | Laser Cutting | Acrylic Fabricators | Perspex ... Services - laser cutting, CNC machining, laser engraving. We offer an extensive range of acrylic sheeting in various thicknesses comprising of a full range ... www.dennyplastics.co.uk/services.asp
Cached - Similar -
Polycarbonate and perspex plastics machined, formed glued and welded Polycarbonate and perspex plastics machined, formed, glued and welded to produce self-supporting structures including Machine Guards. www.aldaplastics.co.uk/polycarbonate_perspex_plastic.html
Cached - Similar -
Industrial Plastic Fabrications - Plastic machining, CNC machining ... Whether your machining requirement is for prototypes, small batches or production runs we can produce high quality perspex and acrylic components to your ... www.ipfl.co.uk/Machining/49/Home.html
Cached - Similar - oldschool.co.nz • View topic - Plastic, Perspex Machining we machine plastic most days, perspex every other day. easy as.. turn/mill, then polish with wet n dry then brasso. lube with crc ... www.oldschool.co.nz/phpbb/viewtopic.php?f=9&t...
Cached - Similar - Online Sourcing the CNC Machining of Perspex Panel by an ... MFG.com is a best-in-class online Sourcing Management System for the manufacturing industry. This page illustrates how an aerospace industry buyer located ... www.mfg.com/.../CNC-Machining-155018-Ilford-Essex-United-Kingdom. html
Cached - Similar -
THE DUCTILE-BRITTLE TRANSITION WHEN MACHINING PERSPEX ... Many materials machine in either a ductile or brittle manner depending on the cutting conditions. This paper identifies the conditions which allow per... www.informaworld.com/.../content~content=a773187886~db=all~order=
page - Similar -
Searches related to: machining perspex
laser cutting perspex perspex acrylic sheet
Good Answers: 74
07/19/2009 2:00 AM
Thank you very much babybear.
I have received this on a Sunday afternoon and those links have made the room smaller. I shall have a closer look and appreciate the time you must have spent trying to help me out.
I shall name this chair after you "Baby Bear". I think it could fit one if not your self one day.
Appreciation from here, Ky.
The Twain Has Met
Good Answers: 68
07/19/2009 2:22 AM
Hello Ky,
I hope you are well and have luck with whatever you decide to do when and if you manufacture it!
No problems, it is my pleasure! I know you have Australia on your profile but, I also know it may not be your domicile. That is why I also included the others. It was too much to do all the Continents though!...........;=)
Let me know how you get on and what you used to make the stuff you photographed please?
I am really interested in this type of furniture........see PM.
Good Answers: 74
07/19/2009 5:28 PM
Hi bb, that is what I am hearing here too. Many have commented and made inquiries about them. That is the reason I came and asked on CR4 but so far it seems to be stuck in the sculpture department. There are, like I said, other advantages which make this design a true novelty and very attractive to have. I can not mention this here because it would give away too much.
The proto types I have were made by using different hand tools Like jig saw and router and a lot of elbow grease and some jigs and tricks.
Talk to you soon, Ky.
The Twain Has Met
07/11/2012 1:46 AM
CR4 ADMIN: Deleted Post
Spam: This post was deleted because it contained advertising outside the Commercial Space forum. Please review Section 14 of the CR4 Site FAQ about advertising.
07/19/2009 5:52 AM
Hi Ky,
A thought out of left field, and I have no idea if it will work. Perhaps piano wire heated by a soldering iron transformer or similar, would "melt" its way through leaving a smooth edge.
Would be important to keep a consistent feed rate to get a good and uniform finish.
It may be necessary to use something other than piano wire if the perspex tries to stick to it.
I think I have some perspex scrap around, so I might give it a try and see if it works.
I'll let you know.
Good Answers: 74
07/19/2009 5:10 PM
Hi sceptic
Thanks for your thoughts on this. I hope you have not gone through the trouble of trying what you are suggesting. I think you will find that perspex is not easy to tame. The heat requiered, to allow for smooth cutting, would bring other problems with it. I have not tried it my self but doubt it would work, while leaving a cosmetically exeptable finish.
Thank you for your input, Ky.
PS: I am still working on the "injector" and have had some very interesting thoughts backed up by some observations known to us all. I shall keep you up to date.
The Twain Has Met
Good Answers: 68
07/19/2009 5:19 PM
Hello Ky,
thanks for the reply post. I am really into this type of furniture!
Good luck.
07/20/2009 8:41 AM
Hi Ky
The definition of "junk" is something you keep for years and then throw away just before you want to use it.
Unfortunately, my stray piece of perspex fits that defintion perfectly, so I was unable to try it out.
07/19/2009 7:24 PM
Hi Ky,
I am the production manager for a signage company based in Maryborough Qld. We cut this stuff all day long on our routers.
I think your designs are very stylish and have some serious potential.
I would be happy to cut you some trial pieces at cost in the hope that more work would follow. I would hesitate to offer accuracy of 0.5mm though, the sheet material doesn't even keep that tolerance.
Ian H.
Good Answers: 74
07/19/2009 8:28 PM
Engraver
Good to hear from you. Just around the corner too. If you handle that material all day you know what I am talking about. Impossible to do were I am. You are realistic about tolerances,I know. These are tolerances when water jet is used, or so they say.
I will send you a private mail regarding this. Thank you for your support, Ky.
The Twain Has Met
12/20/2012 5:03 AM
Hi Ky,
I believe perspex can be cut using a band or scroll saw, if you put masking tape on the cut first to avoid splintering.
This could be a way to make small numbers for prototyping, though water jet would be the way I would go for production.
We need to catch up sometime and scribble on a few more serviettes!
Regards
Good Answers: 74
12/20/2012 2:34 PM
G'day my friend
We'll be up that way soon and I'll drop in or we could meet somewhere else. The perspex treatment and manufacture is solved.
Talk soon, Ky.
The Twain Has Met
Register to Reply 25 comments
Anonymous Poster (1); babybear (3); Chankley (1); Engraver (1); GM1964 (1); ky (11); sceptic (3); scotchdrnkr (1); Sinobaler (1); TinTin (2)
You might be interested in: Cutting Services
