Previous in Forum: centrifugal pump   Next in Forum: Heat load calculation for buildings
solar heat load inside the bulding
07/17/2009 6:37 AM
i need to know the solar heat load calculation and also the other heat loads for HVAC
Pathfinder Tags: heat load HVAC solar intensity
Re: solar heat load inside the bulding
07/20/2009 3:29 AM
Is this the same building as anusharma's?
http://cr4.globalspec.com/thread/40613/Heat-load-calculation-for-buildings
Start with the building drawings, the location, the altitude, the weather patterns at that district, the local building regulations, etc., and go from there. The architect's office is probably the first port of call.
You might be interested in: HVAC Services, Solar Water Heaters, Solar Mounts
