Previous in Forum: Searching for power dense 4-stroke small generator for race-EV application   Next in Forum: 304L
9 comments
steel,welding,ndt,heat treatmrent,structure,phase transformation
07/18/2009 12:15 AM
hello to every body in forum
i put a discussion stainless steel with martensite structure is magnetic. why austenite is non magnetic . any suggestion for the heat treatment( normalizing or annealing) after the welding of stainless steel or the stress relieving of S.S . any ASTM code /standard regarding this .
thanx
moonlight
Re: steel,welding,ndt,heat treatmrent,structure,phase transformation
07/19/2009 12:51 AM
Dear sir.
You may try this site ' www.gowelding.com ' hope you will get all about welding.
Thank you.
V.D.DEODHAR.
07/19/2009 12:56 AM
In my 5 year experience i have never seen any stess relieving of S.S. . in case of welding ,stress relieving is depend upon your apporoved WPS .
07/19/2009 1:29 AM
sir if we do welding on SS or the heat treatment annealing or normalizing)done done to SS does it not necessary to relieve stresses(residual stresses).
suggestion welcome
07/19/2009 5:54 AM
In case welding S.S to S.S similar metal P8 to P8 as per ASME B31.3+ASME sec IX stress relieving is not required after welding regardless of thickness.even though in case of dissimilar metal either p1 (C.s)to p8 (S.S) or P4 (alloy) to P8 (S.S) stress relieving is required only c.S or alloy portion of joint if stess relieving is applicable as per code. stess relieving is not required or applicable for s.s joint.
Spain - Member - New Member Engineering Fields - Nuclear Engineering - New Member
Good Answers: 25
07/19/2009 6:05 PM
Hi all,
Austenitic phase is non magnetic because its structure (FCC) other iron structures BCC are ferromagnetic (well just if they are below its Curie temperature).
Regarding Austenitic SS, usually structural/pressure vessel Codes nor specify nor forbid a stress relieving HT. My experience is that this type of steel is not HT after welding as it's not necessary to stress relief and some problems could arise if HT is done (sensitization, sigma phase....)
So if your material is austenitic SS, don't heat treat it after welding.
Kind regards
07/20/2009 12:42 AM
thanx
moonlight
Good Answers: 18
07/20/2009 1:19 AM
Austenite SS material are FCC structured and they are non magnetic. Since they do not form hard zones, welded joints do not require any Pre / Post welding heat treatment. Sometimes solution annealing at 10450C is done to separate Carbon – Chromium precipitation.
Marten site structure requires preheating, PWHT to avoid cracks during and after welding. There is no such problem while welding austenite materials as they are easily weldable and also have good ductility compared to marten site steels.
What we have done for ourselves alone dies with us: while what we have done for other and the society remains and is immortal.
07/20/2009 8:12 AM
nice and
thanx
07/20/2009 8:16 AM
hello sir
but why FCC is Non magnetic?bcc not .without clarifying it the question remains unsolved.
moonlight
Register to Reply 9 comments
Anonymous Poster (2); Kwetz (1); moonlight (2); munneykhan (2); SRIDHAR (1); vidyadhar deodhar (1)
