Previous in Forum: Suppliers of Fiber Optic Joints   Next in Forum: Electrolyte Capacitors
12 comments
United Kingdom - Member - British
Graphics Cards
07/22/2009 9:52 AM
I am confused which graphics card to buy. I am stuck between a NVIDEA 9600GT super+ (1gb) and a ATI 4670 (1gb). The Nvidea has a 256 bit clock, 650MHz core clock, and a 800 MHz RAM DDR3 clock. The ATI has a 128 bit clock, but it has a 750MHz core clock and a 1700 MHz memory clock. Should I go for a 256bit g card, or should I follow the higher core and RAM speeds?
Here are the links to the cards:
http://www.ebuyer.com/product/153177#
http://www.ebuyer.com/product/164122#
bondy111
Re: Graphics cards
07/22/2009 12:41 PM
It will all depend on what software you will be running.
Most CAD/CAM/CAE systems I have used would prefer the Nvidia card.
Re: Graphics cards
07/22/2009 2:30 PM
I am running XP pro, to play some games, such as Grand theft auto 4.
bondy111
Re: Graphics Cards
07/22/2009 3:25 PM
Have a look at the speed and performance comparison tests that have been done like the following
http://www.anandtech.com/video/showdoc.aspx?i=3405&p=7
They are very, very similar in performance (so similar you won't be able to tell the difference).
I would go with the NVIDIA 9600GT over the ATI (even if it was slightly more expensive due to their better product support and compatibility in my opinion).
Re: Graphics Cards
07/23/2009 3:27 AM
The conclusion on the anandtech website says the Nvidea is an epic fail at it's price point, and to buy the ATI. I currently have an ATI 3450 HD, so based on the review,and my experience, I am inclined towards the ATI.
bondy111
Re: Graphics Cards
07/23/2009 3:02 PM
If this specific Nvidia model is not competitive due to price what about another Nvidia model?
There is after all more than one way to render a car, and you should always look at the entire range of latest and slightly older graphics cards to ensure you are getting the best bang for your buck. Latest model always means expensive but not necessarily the best performance increase per dollar you can spend. Check out the slightly older models of Nvidia cards before you decide what to buy.
United Kingdom - Member - New Member Engineering Fields - Transportation Engineering - New Member Technical Fields - Marketing/Advertising - New Member Hobbies - Target Shooting - New Member
Re: Graphics Cards
07/23/2009 4:58 AM
I am not familiar with Grand Theft Auto or the specific cards in question; however I have noticed that while most games are list nVidia cards as compatible, fewer list ATI cards. I would therefore instinctively lean towards nVidia however I am not a serious gamer so others may be better placed to advise.
Re: Graphics Cards
07/23/2009 9:49 AM
Go with the GTX9800 1GB DDR3, I got this card a couple months ago and it is wonderful.
I'm running it with 64 bit Vista on 8GB of 1000MHz DDR2 RAM, and a multi core motherboard with two 2.8 AMD Processors. I can run 3 Cad programs at once and not lag. Crysis runs like a champ, and Fallout3 on ultra graphics runs at a smoking 98 FPS.
The GTX9800 1gb DDR# will cost you no more than $160 and is one of the only cards under $200 that can compete with the $400+ cards. You will need a PCI express slot though.
You can also duel the card out later on and run two in relay on your board! =] FUN FUN!
Re: Graphics Cards
07/23/2009 12:23 PM
Both are too good for your eye to notice a difference.
Yahlasit
Good Answers: 97
Re: Graphics Cards
07/23/2009 3:18 PM
Hello Bondy,
Before we can ascertain which card is of greater benefit to you, we need know more about your computer component spec's; mother board, CPU, RAM etc. and what type performance you expect from it.
Re: Graphics Cards
07/24/2009 6:35 AM
Motherboard - Gigabyte GA-M52L-S3 nForce 520LE Socket AM2 8 channel audio ATX Motherboard CPU - AMD Phenom X4 9650 2.3GHz Socket AM2+ 2MB L3 Cache RAM - 2GB DDR2 - SDRAM PC6400 (400MHz) UDIMM 500W PSU. I am just wanting to play it with a reasonable graphics, and good performance - On GTA4 the lowest settings look fine (My monitor is not HD) (1024x768)
bondy111
Good Answers: 97
Re: Graphics Cards
07/24/2009 1:24 PM
Frugality: GIGABYTE GV-NX84S512H GeForce 8400 GS 512MB 64-bit GDDR2 PCI Express 2.0 x16 HDCP Ready Low Profile Ready Video Card
*Budget conscious: EVGA 256-P2-N768-FR GeForce 8600 GTS SSC Edition 256MB 128-bit GDDR3 PCI Express x16 HDCP Ready SLI Supported Video Card
**For the modest gamer: EVGA 512-P3-N871-AR GeForce 9800 GTX+ 512MB 256-bit GDDR3 PCI Express 2.0 x16 HDCP Ready SLI Supported Video Card
Cruising: Sapphire HD4870 1 gb
Authoritative: EVGA GeForce GTX 285 SC
The spec's given by programs indicate and absolute minimum don't go that way unless you prefer to learn by not getting what you want.
† Be sure to provide good air flow in the case for the G-card when purchasing low end products especially.
Hope this helps
Re: Graphics Cards
07/24/2009 8:25 AM
Rockstar recommends a 256MB NVIDIA 7900 / 256MB ATI X1900
bondy111
Register to Reply 12 comments
Anonymous Poster (2); Bondy111 (4); bwire (2); Calnet42 (1); Chankley (1); jack of all trades (2)
