Previous in Forum: Fine Tuning a PID Loop   Next in Forum: Exciter Function in Three-Phase AC Generator
8 comments
Good Answers: 97
Remote Current Monitoring
08/05/2009 2:20 PM
I have an application involving a simple dredging operation, whereby the dredge pump will be suspended from a remote control hoist mounted on a pontoon float, and moved vertically into and out of a layer of sediment at the bottom of a pond.
In order to provide optimum pumping and avoid overloading this pump I need to be able to provide pump motor current draw information to the hoist operator, who will be located at some distance from the onshore motor control panel.
I have investigated radio links, but can't seem to locate one that will relay a simple analog (current level) signal (provided by the output from Ct's) from the control panel to a small battery powered indicator.
I have considered a simple "light tower" or annunciator with three colors to indicate under-current, normal full load current and over-current, mounted on the motor control panel and visible to the operator.
This annunciator would need some sort of driver to convert the analog current signal into the three colors.
The pump will be Three Phase 480v. the panel control voltage can be 24 to 230vac.
Any suggestions?
CRTL-Z
Pathfinder Tags: Remote Current Monitoring
Good Answers: 53
Re: Remote Current Monitoring
08/05/2009 10:53 PM
You can feed CT output to a V to F converter,driving an infrared transmitter. that can be sensed at a reasonable distance with a receiver.Which again can convert revived signal in voltage.
08/06/2009 12:43 AM
How far is the hoist operator from the motor control. What is your approximate budget for this system? Is $10.00 too much or is $500.00 reasonable? The reason I ask is the cost of a simple transmitter that is reliable may cost $150.00US
Good Answers: 97
08/06/2009 9:39 AM
At this point, I do not have information as to distances. There are complex telemetry systems and even fully automated dredges, but I feel this can be accomplished with a simple system.
The Voltage to Frequency conversion sounds interesting. Is there a source for this?
Thanks for the replies!
CRTL-Z
08/06/2009 3:51 PM
1. The one important parameter is the distance you want to communicate. without that there is no where to go.
2. Are you talking 200 yards or 2 miles? Do you want to build such a device or want to buy a device.
There are data acquisition companies that will build a system like you are talking about. Chances you will not find exactly what you want, but people can build it from modules. But, you can't even talk to them if you do not know what the distance.
I worked for a company that built a similar system for a gravel or mining company That wanted to know how much ore was in a bin 3 miles away. We built a transmitter device that read a strain gauge that told them when to send a truck to pick the stuff up. I think it cost about $3500. That wasn't much considering it cost $6000 to repair the bin after overfilling. 5 years later --still working fine. I think one of the companies that build things like that is Alligator Technologies in California. It is a small data acquisition group. Look them up-- alligatortech.com
rgalter@alligatortech.com
Good Answers: 804
08/06/2009 7:31 PM
I think he is right. Distance is key here. Lets start there because there is simple yet effective technology to do what you want, but the distance is a crucial element in how to start off. Also, can there be a hard wire, even a small instrumentation cable, or not? Surely if it's an electric motor, you are getting power out to it already. Where is that power coming from, and can't the current detection take place there?
08/07/2009 5:53 AM
Are the pump & hoist generator powered? If so, entire control system could be onboard. An economical 8 function radio control could be set up for shore operation.
me thinks, therefore I am - I think?
08/07/2009 9:36 AM
As a matter of fact. The remote gravel sensing system was indeed a 2 channel R/C transmitter and receiver. The DC signal from the strain gauge transducer 0-10vdc was fed into the Radio Control transmitter. Right at the control pot. it varied the pulse width of the transmission 0-2 msec. On the other end(receiver) the pulse width was filtered with Res /Cap and read with an analog meter. The over-all system accuracy was 1-2%. More than enough for that application.
Good Answers: 97
08/07/2009 9:58 AM
Many Thanks to all who replied, I found the solution at:
www.remotecontroltech.com
CRTL-Z
Register to Reply 8 comments
JRaef (1); leskranes (1); Mooseman (3); rakesh_semwal (1); Unredundant (2)
