The following came up in a recent car talk discussion with friends--
In recent, electrically shifted (shift by wire) automatic transmissions, how are gear changes accomplished? More specifically, is a positive "shifting force" applied for both up shifing and down shifting? Or is it a matter of force application to change up (or down) and force release (removal [or application] of signal) to change down (or up)?
Or is is simply a matter of ... replicating the action of a stick shift linkage...where applying mechanical force to select one gear (also applies "opposite" force and) disengages another gear mechanically...without need of electric signal input to the de-selected gear?
Thank y'all.
