Previous in Forum: Fan Shafts   Next in Forum: Condition for PQR to support WPS.
11 comments
Canada - Member - New Member
Good Answers: 39
Ebullating Assembly?
09/10/2009 3:00 PM
Here I am the Customs broker caught between the importer, exporter and Customs officers.
Can anyone tell me what an Ebullating Assembly is? Based on who the importer is it will probably relate to the oilfield or refining industry. As this may quickly become a legal issue I won't use any names. The thing is worth almost 3 million dollars and all I have so far is someone told us "It's a pump"
If that much is true then does anyone know if it is a positive displacement reciprocating, rotary displacement, centrifugal or some other pump. Or is it a much larger contraption with a pump in it?
Any help would be appreciated.
All that is required for evil to succeed is for good men to do nothing.
Pathfinder Tags: ebullating oilfield Pumps
Good Answers: 39
Re: Ebullating Assembly?
09/10/2009 3:59 PM
Hmm I think i have found something that may alloow me to refine my question.
http://www.kbcat.com/default/documents/technical%20papers/tp%202006/2006_Mar_Ebullationfactor_HydroEng_SSayles_KBC_O.pdf
Unfortunately the article explains what the ebullating assembly does but not what kind of pump sits at the bottom of it.
Now would I be off base if I assumbed that due to what it pumps, heavy oil, with much contamination in it, that a centrifugal pump would be the best type? Would this pump be submerged in the oil?
Good Answers: 1693
09/10/2009 6:43 PM
I've not come up with much, except this:
DEEP CONVERSION OF HEAVY OILS VIA COMBINATION OF THE H-OIL PROCESS ...the ebullating pump (a canned centrifugal pump) which varies the flow of ebullating liquid obtained from the internal vapor/liquid ...
www.onepetro.org/google/Papers/WPC/.../16v03p0111.pdf?id... - Similar
by JJ Colyar - 2000
Hope this helps.
09/10/2009 7:35 PM
I think its your "much larger contraption ...". Have a look at this document.
09/11/2009 3:56 AM
John, Did you mean to reference the same document as Apothicus found in post #1?
09/11/2009 4:22 AM
- sorry, Apothicus, should've checked your link first. Respect!
[Randall - thanks for the heads-up]
Good Answers: 1693
09/10/2009 11:39 PM
OK,
It's a chemical conversion/replenishment system, that uses a centrifugal pump to maintain system balance.
Canada - Member - New Member Engineering Fields - Mechanical Engineering - New Member Engineering Fields - Piping Design Engineering - New Member Hobbies - DIY Welding - New Member
Good Answers: 11
09/11/2009 10:41 AM
So here I am sitting in the middle of a 6 billion dollar construction site building a heavy oil plant trying to clear out our warehouse to make room to remove a couple of ebullating assemblies....
The ebullating pump is a centrifugal pump that sits below a reactor tower filled with catalyst. Catalysts tend to be solids (ie: don't float well) and cooler than the surrounding liquid as the chemical reaction they are helping usually absorbs heat. Both effects cause them to settle to the bottom of a reactor over time. The ebullating pump recirculates the cool and catalyst-rich production fluid from the bottom of the reactor back to the top of the reactor. The fluid is usually sent through a re-heater to warm the catalyst and fluid back to the reactor operating temperature before re-injecting it back into the reactor. The situation mimics the recirculation of fluid in a boiling pot, hence the term ebullating, from the French verb "embouillir". "em" + bouillir" = "to place + boiling".
There are usually numerous suction feed pipes from the reactor to the ebullant pump and they can be quite complex. The numerous pipes are needed to ensure uniform draw from all around the bottom of the reactor. Otherwise hot or cold spots form, causing carbon deposits to form ("coking" when heavy oil is concerned) and plug the suction lines or pump.
Since the pump and suction pipes are subject to frequent plugging caused by coking and catalyst deposition, the pipes and pump are removable. They are installed on a common structural steel skid as a complete assembly called - now wait for it - the ebullating assembly. The skid suction and discharge piping is attached to the reactor with high pressure-temperature clamps (Securemax). The whole assembly can be removed and another quickly installed to keep the reactor in operation. The removed assembly can be sent to a maintenance shop for flushing with high pressure water chisels, as the coke is like concrete once it bakes on to the pipe walls or pump casing.
Hope this helps!
Cheers,
Steamer Stan
"You are, what you do, when it counts" - John Steakley (Armor) 1984
Good Answers: 1693
09/11/2009 11:19 AM
Now that is a good answer!
Good Answers: 39
09/11/2009 11:22 AM
Thank you all, we have it properly classified now as a centrifugal pump, non-submersible. A special thanks to Steamrest, what you described is exactly what we have, in fact looking at your location, the units we are discussing may well be the very units you will be installing. Small world isn't it? We show a delivery location as Fort Saskatchewan but that is right in your neck of the woods I'm told. I'm a recent arrival to Alberta so still not sure of all the geography.
If it turns out that they are yours, the third one has arrived and is on it way to you. I hear there are 2 more coming shortly.
Good Answers: 68
09/11/2009 10:27 PM
Hi Steamerst,
GA to you Sir for a very good answer.
Take care
Good Answers: 68
09/11/2009 10:23 PM
Hi Apothicus,
The phrase '"Ebullated" Assembly" is from 'ebullition', which means "boiling" and "effervescence".
ebullition vaporization - Ask.com Search
An ebullition cooled transformer has a housing, a core and coil assembly ... Also the vaporized portion of the fluorocarbon located above the core and coil ...
dictionary.reference.com/browse/ebullition%20vaporization - Cached - Similar -
Let me know if this is of use please?
Register to Reply 11 comments
Apothicus (2); babybear (2); JohnDG (2); lyn (3); Randall (1); Steamerst (1)
