Hello All,
This is only my second time addressing this forum folks after having been a clinging wallflower for a couple of years.
Well, hopefully someone here will be able to answer a question that I have concerned with the proper selection of insulation materials for use in one of my "little" energy projects that I have going on around the house. Presently, I am building a DIY Solar Thermal System incorporating glass encapsulated tube collector technology. I am running into problems (even w/ Googling) trying to find the most correct insulating material to use in my project which is inexpensive and easy to install, yet able to withstand the high temperatures created in heat bulb located at the tops of the collector tubes where they're connected to the copper pipe manifold. I'm also looking to wrap the copper supply and return piping (possibly located inside PVC carrier pipes???) with the same insulation material. I'm trying to utilize salvaged materials here as much as possible and keep them out of the landfill.....trying to be a responsible Earthling!!!***LOL*** As I understand it from my research, these salvaged collector tubes (former NASA evaluation testbed) are each capable of producing at least 350 degrees Farhenheit maximum temperatures at the heat bulb/manifold juncture.
So far, I've identified "Rock Wool" as a potential insulation material, but I don't know what it is, how much prolonged heat it can withstand, and where I can obtain it. Does anyone have any information in regard to this material, or does anyone have any suggestions on what other types of insulation material I could or should use? I want to minimize thermal heat loss as much as possible, especially during our cold winters here in upstate New York. List of perspective material suppliers too???
I'm just a lowly Civil Engineer, and not a mechanical Engineer or a Rocket Scientist, so please take it easy on me guys and gals!!! ***LOL*** TIA, and have a great weekend guys!!!
===DaMoosie
PS: This is a mini-posting for Del-the-Cat. I came across a forum posting of yours last evening, dated around Sept., 2008 (?), concerning what material to use inside the heat pipe/bulb of your encapsulated collector tubes used in your solar hot water system. May I suggest that you try liquid MEEK, amongst other liquids. You'll need only a tiny amount present inside your sealed heat pipe. You can buy the stuff by the pint, quart or gallon at your local hardware store. Fairly inexpensive stuff, but watch yourself when soldering the ends of your heat pipe and heat bulb!!! If you should have a questions, feel free to contact me, and I'll send you a good URL link regarding the construction of heat pipes. ***CHESHIRE MOOSIE GRINZZZ***
