Previous in Forum: How do businesses in US view low cost packaging machinery from India & China?   Next in Forum: lunar trip
35 comments
Popular Science - Biology - life lover Hobbies - Musician - music lover Safety - Hazmat - better safe than sorry United Arab Emirates - Member - desert trek Technical Fields - Procurement - procurement
Good Answers: 58
what would happen to the metal slab
09/27/2009 8:17 AM
being reminded about the deepest part of the sea, which is the Challenger Deep in the Mariana Trench, where the bottom is said to be 10,924 meters (35,840 feet) below sea level (so deep that if Mount Everest, were placed at this location it would be covered by over one mile of water), I couldn't help but wonder what would happen to a hypothetical piece of metal slab (any grade) weighing a ton dropped directly over the deepest spot.
would it:
  • be crushed into a very dense pulp, or into a smaller size, and continue to sink right to the bottom?
  • be crushed and be suspended somewhere where it attains some "bouyancy"?
I am intrigued. any theories or practical experiences that can shed light on this? BTW, this isn't some homework. I'm actually planning to use this as an illustration, one day.
- langyaw
Now the darkness only stays the night-time, in the morning it will fade away. -- George Harrison (All Things Must Pass)
Good Answers: 143
Re: what would happen to the metal slab
09/27/2009 9:13 AM
Google "Trieste". There's even a video documentary, about a half hour long, though I've no idea where to find it.
Good Answers: 58
09/27/2009 9:24 AM
<LOL> where was I in 1960? I thought the bathyscape never made it to the bottom! I'll try to find the video later.
thanks for answering a dummy's question!
Good Answers: 143
09/27/2009 9:32 AM
Not a dumb question. If you ever find the video, watch for what happened to the plexiglass.
Good Answers: 119
09/27/2009 12:10 PM
Compressive forces are large, but not large enough to deform solid steel.
Basic info here... http://en.wikipedia.org/wiki/Mariana_Trench
Saw this program recently... How the Earth Was Made - The Deepest Place on Earth
http://www.history.com/shows.do?action=detail&amp;episodeId=482034
I already knew the basic historical events, but I found the additional details presented both entertaining and educational.
Good Answers: 15
09/27/2009 10:43 PM
I decided to follow the 2nd link, just starting lunch break, thought it would be a educational Lunch Break
We're sorry, the page you requested could not be found.
We are continually working to improve our sites and the page you are looking for might have been removed, had its name changed, or is temporarily unavailable.
Qn, Whats the differance between a Snake and a Onion? Ans, No one cries when you chop up a Snake
Good Answers: 119
09/27/2009 10:56 PM
2nd link works for me, but it is NOT the actual TV show. It is just a brief summary of the episode as shown on "The History Channel" here in the North East USA. There are links to find other show dates, but this particular episode is not scheduled for replay anytime soon. There are also links to purchase the DVD series "How the Earth Was Made" which contains this episode. Sorry for any confusion.
There are some online episodes, but I can't find the one on the Mariana Trench. Try this one.
http://www.history.com/video.do?name=How_the_Earth_Was_Made
Good Answers: 1693
09/27/2009 9:20 AM
It would sink to the bottom, and rest there.
Nothing more. It's a solid chunk of metal.
09/27/2009 2:09 PM
You forgot, it will get wet
Good Answers: 1693
09/27/2009 6:44 PM
"You forgot, it will get wet"
You covered it.
Good Answers: 183
09/27/2009 9:42 AM
Density changes with depth. If we consider 1.03 kg/dm^3 as constant over the depth (which is not totally true since near to surface water contains air in solution and thus is lighter) and the bulk modulus as 2.2E3 MPa then at 1.1E4 m depth will be 114 MPa.
Pressure coming from all directions the part will be loaded but cannot be destroyed.
The vertical force - Archimedes- will be 1.0834/7.85 of the weight not enough to float the steel part. 1.0834 is the density at the bottom for the values mentioned above.
Conclusion the part goes to the bottom and either rusts or wait till it will be harvested if ever.
Good Answers: 58
09/28/2009 2:22 AM
best answer, IMHO. GA there!
09/27/2009 9:42 AM
It would sink and get wet.
Good Answers: 25
09/27/2009 10:44 PM
And very, very cold.
Jon
Good Answers: 183
09/28/2009 12:26 PM
1- temperature is not as low as you think so tha it can only become cold (>0°C) and
2- what if it falls near to a hot source with a temperature over 200°C?
3- as an answer to the "oxigen" problem rust if there are ions H-O then as far as I know rust can develop.
09/28/2009 7:55 PM
And very, very cold
here i was thinking, heat of compression might warm things up a bit
Good Answers: 120
09/27/2009 11:21 PM
A solid metal will be very slightly compressed, you would have to canculate it from the tables for that length and thickness. It might shrink 1/100 of a percent, really very little, not enough to change the bulk density to make it stable at one depth.
The trieste was a balloon of steel with a flotation "gas" of gasoline,(later kerosine for fire risk) which is a little more compressible than steel, but still virtually incompressible at 35,000 feet..The people were in a steel sphere with special conical windows.
It was ballasted with steel pellets held in place with an electro-magnet powered by a lead acid battery, also in the kerosine. As the electromagnet depletes the battery and the magnetic field drops, the pellets are lost and this made a fail safe auto flotation device.
http://en.wikipedia.org/wiki/Bathyscaphe_Trieste
The russian "trieste" is similar, but had a titanium shell for the people, and was thus lighter = smallerI recall in my youth reading about William Beebe, who went down a few thousand feet in a cable hung steel ball. They could not go very deep, as the weight of the cable was a limiting factor as it soon reached it's self supporting weight with the sphere on it, and so they hade to stay away from that limit by some safety factor.
http://en.wikipedia.org/wiki/William_Beebe
Per Ardua Ad Astra
09/28/2009 7:53 AM
It would set there and slowly rust would it not be suspened at around 8700 feet then swept by currents ? Just a quick calcuation in my head.
The Titanic comes to mind even fine glassware was in tact but other thing were cracked where voids inside made it weak but the pressure of the water caused the damage to only that weak area during descent. It is instant not a slow effect.
09/28/2009 8:42 AM
It's a good question, and it looks like you have the answers(though I haven't checked all the links yet). One thing puzzle me ; "I'm actually planning to use this as an illustration, one day."
Of what ? Do you men in some artistic sense, or are you going to explain this to others in some teaching capacity. Performance art even ? I'm not taking the ****, I can see good potential in all those scenarios.
Seemingly straightforward questions often result in interesting discussion. (Damn, I wish I'd though of this one). I could point you to a bunch of links that relate to the question, but I think people have already covered the bases there. I'm just being a little nosey about your meaning with that phrase,
Good Answers: 58
09/28/2009 9:22 AM
hi Kris,
curious, huh? well, in the Bible, in Micah 7:19, it says "He will turn again, He will have compassion upon us; he will subdue our iniquities; and Thou wilt cast all their sins into the depths of the sea." immediately the Marianas Trench came to my mind, and the imagery comes alive, picturing all our sin packed in a box, and dropped in there by God Himself, intending for it to be forgotten and never brought up again. that box will be crumpled into a shapeless mass, perhaps pulverized into nothingness by the sheer pressure, doomed to a cold dark limbo, beyond recovery.
for those who believe, God's grace is truly amazing!
I'm a pastor. so it'll be an excellent illustration for a future sermon.
Good Answers: 183
09/28/2009 12:29 PM
Pandora's box ?
09/28/2009 1:55 PM
But can you crush hope, which was all that was left in the box ? I think not.
Good Answers: 25
09/28/2009 9:56 PM
Langyaw,
Reflecting on your idea:
Tangible objects can be destroyed by forces of nature.
Intangible objects are not effected by any force of nature.
Sin is an intangible concept that you would have to give substance to, like creating an idol that represents it, in order to confine it and destroy it in the deepest place in the sea.
Or you could attach the sins on a goat and send it to an uninhabitable place.
Good luck with the imagery.
Jon
09/29/2009 3:27 AM
Another bonkers religious concept..
The whole point is surely to avoid 'sinning' in the first place.
I shall have to unsubscribe if the R word is going to polute this discussion.
Good Answers: 179
09/29/2009 9:25 AM
Hello All,
I for one have to agree with "Mr. Del the Cat" where the "R" word doesn't belong whatsoever in this forum. Ditto with the dreaded "P" word too. My Grandmama taught me an important lesson when I was just a wee lad, and that was that one did not discuss Religion and/or Politics with family and especially not with strangers....it makes for strange bedfellows and bad blood. It's too bad my X didn't heed these words when talking to dear 'ole Grandma during the 1980 Presidential Race 'cause she got a wicked tongue-lashing from Grandma just before we were married. heheheheehe Hell, X deserved it, and I laughed inside for days afterwards. It did teach X a very valuable lesson to shut her all too open "pie hole".
And for you guys with dirty thoughts, the "P" word that I'm inferring to is NOT the thing that most of ya think with! *LOL*
Enough said about this thread.....it's a dead duck and it's high time to close up the shop talk on it! Whatsyasay Mr. Webmaster?
My 2 Cents for what it's worth.....anyone care to flip a coin guys??? CHEEKY CHEEKY CHEEKY LOL
Good Answers: 25
09/29/2009 9:56 AM
CaptMoosie,
I agree.
Jon
Popular Science - Weaponology - Cardio-7
09/28/2009 9:22 AM
The only way a steel something could be crushed at that depth was if it were hollow, and the outside pressure was sufficient to crush the object. The steel itself would not be affected by the pressure, and I doubt if there is enough oxygen at that depth in the ocean to rust the steel. Steel plate can be "molded" or formed by explosive charges that far exceed the pressure of the deepest part of the ocean, but those explosive forces only form the steel, they don't "crush" it.
09/28/2009 10:52 AM
Re: "I doubt if there is enough oxygen at that depth in the ocean to rust the steel."
Please, please, please do not encourage people ... especially in such a fine forum as this ... to perpetuate incorrect thinking...!
That's what 'grandpas' do, when explaining to their offspring that the reason they're stuffing bondo into that hole in their rocker-panel is because it got ate up by 'electrolysis'.
Redox reactions do NOT require oxygen to take place. PERIOD!
Just because the reduction of oxygen is the most common (reduction) reaction in the splash zone (marine environment) doesn't mean that "rusting" wouldn't occur if there were no oxygen.
Since you already know this ... for the sake of the unenlightened, who occasionally frequent this forum FOR enlightenment's sake ... (I humbly suggest) edit all subsequent posts to reflect the full spectrum ~ e.g.: "oxygen content of the water at that depth in the ocean is miniscule, and thus, in the absence of any pollution products that would substitute for reduction-purposes, rusting of the steel would be minimized."
sputter....gasp.....vent.....
Good Answers: 179
09/28/2009 12:40 PM
Nothing would happen to the metal, except get wet and slowly rust, as there's very little "free" dissolved oxygen in the water at such a great depth. Ummm, let's observe the KISS Principle here folks....
Anyhow, the water pressure would be acting on it from all directions....
.....and we shall chant Sir Isaac Newton over and over again until it's engrained in our meager braincells forever and ever more..... "for every action (in this case force or pressure), there's an equal and opposite reaction".
there's my 2 Cents worth...ain't worth much...can't even buy a Boozoka Joe Bubble Gum for that amount now days...*SIGH*
09/28/2009 3:03 PM
I remember when I was a kid, my grandmother worked on a NOAA research ship doing work over the trench. She sent us (my siblings and myself) styrofoam coffee cups that had been to the bottom. The immense pressure had forced out all the gasses trapped in the styrofoam, shrinking them down to roughly the size of a shot glass (I'm not sure if they started out as 8, 12, or 16 oz cups). I remember they had the texture of rough plaster.
This "real world" experience leads me to question if in fact nothing would happen to the steel plate, or if it would in actually change shape ever so slightly depending on the quantity and distribution of trapped gasses inside, and possibly even the grain structure of the materials in the metallic plate. Its well known that certain iron alloys change grain structure and composition when exposed to various temperatures and pressures (cast iron being notorious for this).
Good Answers: 119
09/28/2009 8:13 PM
To recap most of the info already posted...
Bottom of Mariana Trench
Pressure is 108.6 [MPa]
MPa conversion to PSI
http://www.chapelsteel.com/mpa-psi.html
or 15,751 [PSI]
Yield Strength
http://en.wikipedia.org/wiki/Yield_(engineering)
Even the weakest steel on the list has a yield strength >2x the pressure at the bottom of the Mariana Trench. No permanent deformation should occur to a solid piece of steel.
Good Answers: 120
09/28/2009 9:01 PM
The bulk modulus (K) of a substance measures the substance's resistance to uniform compression. It is defined as the pressure increase needed to cause a given relative decrease in volume. Its base unit is Pascal.
http://en.wikipedia.org/wiki/Bulk_modulus
As an example, suppose an iron cannon ball with bulk modulus 160 GPa is to be reduced in volume by 0.5%. This requires a pressure increase of 0.005×160 GPa = 0.8 GPa116,000 psi).
now the Mariana Trench is 35,000 feet or about 1100 atmosphere or about 16,000 PSI, so said bit of steel would get about .07% smaller. Water is 10 times as compressible as steel
Per Ardua Ad Astra
Good Answers: 119
09/28/2009 9:27 PM
Good link to bulk modulus.
Agree with calculation that the volume of said steel cannon ball should decrease ~0.07% at ~16,000 psi.
Follow-up question:
Doesn't it return to its original volume once returned to the surface?
Good Answers: 120
09/29/2009 9:06 AM
I am not sure if the iron cannonball would expand back to its former size, or if some shear event might occur due to crystal slip etc that may even make it larger or cause a crack or 2 on the way down or up?
Per Ardua Ad Astra
09/29/2009 8:35 AM
I really expect better answers than this.....
.... a slab of metal of any grade? and we don't get anything more exciting than 'sink', 'get wet', 'rust'.....
... ok, this one requires a little luck. drop a solid slab of 3/2.5 titanium ... hydrogen embritlement accelerates as depth increases, extreemly cold temperature, high pressure and hard rock at the bottom causes it to fracture..... the loud sound sends Greenpeace into a panic.
....i like this one more..... one ton of Sodium, pure. dropped into the ocean. ..........highly unlikely that one makes it even 1 mile down.
benbenben
COME ON, I bet you guys can think of some more....
Good Answers: 68
09/29/2009 10:37 PM
Hello langyaw,
Almost needless to say; the Ton of metal will always be more dense than the sea water. So not much will happen to it other than it going rusty and maybe fish and or wave action will wear away at the rust until the metal is gone. But, that will not be for perhaps 300 or 400 hundred years. Interesting though.
Take care
Register to Reply 35 comments
Anonymous Poster (4); aurizon (3); babybear (1); CaptMoosie (2); Cardio07 (1); dadw5boys (1); Kris (2); kudukdweller9 (3); langyaw (3); lyn (2); mjb1962853 (4); nick name (3); Snaketails (1); TVP45 (2); user-deleted-1105 (3)
