Previous in Forum: Mtech Project - Diesel Engines   Next in Forum: what is milwright
density of ice
09/28/2009 8:33 AM
why density of ice is lesser than water?
Good Answers: 38
Re: density of ice
09/28/2009 8:49 AM
Sounds like homework! The answer is not what you think. Ice floats! Does this make it more or less dense than water? Why? Any change in the structure or MASS? If you freeze water in a tight container, what happens?
The last fight was my fault. My wife asked "What's on the TV?" I said "Dust!"
Good Answers: 1693
Re: density of ice
09/28/2009 8:24 PM
"If you freeze water in a tight container, what happens?"
Freezing Water and Pressure
Good Answers: 101
Re: density of ice
09/28/2009 11:31 AM
Because it's neither equal to nor greater .
Re: density of ice
09/28/2009 12:36 PM
Ice actually is less dense than liquid water. The molecules line up as they crystallize and cause a slight swelling in volume. More volumetric area vs. same weight = less density.
MRH - "The search for truth is more precious than its possession." Albert Einstein
Good Answers: 38
Re: density of ice
09/29/2009 6:33 AM
I tried not to be so direct since it sounds like homework. We don't do homework, but we do lead them in the right direction.
Welcome MRH620. Stick around and join the funny farm and you'll see what we mean.
Chaz
charsley99 (2); DVader1000 (1); lyn (1); MRH620 (1)
