Previous in Forum: Electrostatic Precipitator   Next in Forum: Cable Types
Measuring Powder Levels
09/30/2009 2:35 AM
Can anyone suggest the most accurate instrument for the level measurement of powder in a silo
Re: Measurement of powder level
09/30/2009 3:32 AM
Yes, indeed. The required instruments can be found in the Endress + Hauser and the Vega catalogues (usual disclaimers), among others. However they only give volume which, in the case of a powder, might vary with compaction and moisture content depending upon what it is, which hasn't been stated in the original posting. Rather than volume, one might also try placing the complete silo on weigh cells and weighing it instead, perhaps? Weight measurement would knock out the compaction variable, leaving moisture content as the variable factor.
09/30/2009 2:57 PM
There are many different ways but it really depends on the application and vessel size.
What exactly is the powder?
Is the powder fine or granulated? Is it aerated due to process agitation?
What is the size and height of the vessel?
What is the width of the vessel?
What is the vessel made of (steel, stainless steel, plastic, etc. effects which sensors will work)?
How is the vessel filled and emptied (effects level shape and possibly aeration making measurement more difficult)?
Is the powder prone to forming a sinkhole in the middle of the vessel during emptying making level measurement more difficult)?
What measurement accuracy is needed?
There are probably other questions but these are the main ones I can think of. As for a really quick answer, probably non-contact microwave radar is your best bet (but it is one of the most expensive if not the most).
http://en.wikipedia.org/wiki/Level_sensor
Re: Measuring Powder Levels
10/01/2009 2:32 AM
One very simple way is to put a load cell under one foot.
You can always tell the pioneers - they are the ones with arrows in their backs.
10/01/2009 4:24 AM
http://www.monitortech.com/product_conti.shtml
http://sensors-transducers.globalspec.com/Industrial-Directory/grain_silo_level_sensor
http://www.automation.siemens.com/w1/sensor-systems-raw-material-silo-level-13863.htm
bioramani
Register to Reply 4 comments
bioramani (1); hazman (1); jack of all trades (1); PWSlack (1)
