Hello all,
I hope some of you good folk can give me some pointers regarding the proper use of blazing rods and applied techniques. I haven't done any brazing welding since Metal Shop back in high School 33 years ago.
I plan on brazing some copper pipe and fittings together with some brass fittings using brazing rods. The reason that I'm planning on doing it in this fashion is that the process temperatures for my DIY Solar Thermal collectors will be reaching about 350 degrees F. Now, if I implement curved linear fresnel lenses, than this temperature will be much higher depending on how I locate the focused rays of the sun in respect to the encapsulated glass tube surfaces. I'll have to do field experiments to determine the optimum focal length, etc., so as not to bust the very expensive glass tubes, but that isn't the issue here and why I need your help.
My questions are as follows:
1). What would the best brazing rod for me to use; bare rod or flux coated?
2). Should I be looking to use brazing rods with at least 15% silver content or greater? I understand that using silver in tin/silver solder helps resist higher process temps, so is this equally true also brazing rods with similar silver content?
3). Should I be applying a flux paste to the copper/brass pieces that will be welded together?
4). If so, is the flux paste used for soldering work identical for brazing work, or is there a specific type or brand I should be purchasing?
5). Can I use bottled MAPP gas to braze, and will it achieve the required temperatures needed for brazing welding? I have very good and top notch torches and want to avoid renting gas bottles even though I do have the proper gas welding equipment....there's just not that much welding to do to justify the outrageous costs involved with bottled gas.
6). Is the prep work used in soldering work of copper pipes and fittings identical to that utilized in brazing welding work?
I think that's about it as far as the questions go, unless you good folks can come up with some good pointers. Are there any great online resources available, like in U-Tube and elsewhere?......online videos are a great way to learn. TIA, and please have a great weekend!!!!!
