Previous in Forum: More on Climate Change   Next in Forum: Use the Scientific Method to Test the "Scientific Method"!
Water Resistance Testing
10/05/2009 8:11 PM
We have 3 types of netting all in the same mesh or opening size and all in the same thickness (denier/ply). Each netting type HDPE, Nylon (PA) and a high tensile strength hybrid PE.
We wish to attach these nettings in one of the two shapes to a frame and a load cell to determine bollard pull at 3 knots. * Bollard pull will be used to determine the more "easier" towing netting.
Given two distinct shapes of a netting material, one CIRCULAR and one RECTANGULAR. Each one has the same amount of netting around the circumference, 188". Each will be assembled on a 1.25" OD frame of aluminum.
Each one has an 8" spherical ball of hardend plastic to maintain the shape of the netting as it is pulled.
There is now a stalemate on this project as some say the rectangular shape is better suited for testing water flow.
I am asking you all for opinions.
Which of these two shapes would be BEST suited to test the resistance of the 3 types of netting through the water?
* The Round shape will be the more stable as it will not "rock" back and forth as water pressure hits it. Experience has shown that a RECTANGULAR frame will be
Smitty
Re: Water Resistance Testing
10/07/2009 2:42 AM
The circular version has slightly greater cross-sectional area, and as the net fills up (and the resistance or pull thus increases), I think this would also result in the greatest ultimate bollard pull. But not by very much over the rectangular version. On the other hand, the rectangular version may be a closer representation of various practical shapes you might be designing toward. Overall, too close to call? You might just go with whichever is easier to fabricate, and hope for a good school of fish to give it the real test!
10/08/2009 10:14 AM
Thank you.
Smitty
Hobbies - Musician - New Member APIX Pilot Plant Design Project - Member - New Member
10/07/2009 10:04 AM
It would appear to me . . . that shape of the net will have great influence on flow characteristics . . . laminar flow disruptions. Thus . . . the geometry of the net will have great impact on flow characteristics. If flow regimes shift from laminar to turbulent the differential pressure induced by the turbulent flow will produce variations in differential pressures . . . perhaps the reason for the oscillation in the rectangular shape verses the round. Along the surface of the moving membrane, in this case the net, waves will be induced as the pressure wave travels down the net. Therefore, the changing differential becomes significant when shape of net is the critical factor. Ultimately what I am trying to say, is that shape can sway your data. Traveling waves inside of the net ultimately are addiative. My hypothesis is that given the same material of manufacture, that the rectangular shape will show more bollard pull than will the round. If I were doing this test . . . I would build a data base of both shapes and compare the performance curves.
A government big enough to give you everything you want, is strong enough to take everything you have.
10/08/2009 10:16 AM
Thank you also.
The idea is still on the board for discussion as to which to go with but we may do both as is suggested, as some involved want more data anyway.
Smitty
10/08/2009 1:55 PM
Hi Smitty
Why don't you contact a trawl net manufacturer. Most have software that can model this and give you a theoretical answer. However, I still think your best bet would be to make up the two designs and physically test them.
Brgds
Do it while you still can!!
10/08/2009 6:07 PM
The small little trial project suddenly wound up as a point of contention with several "specilaists".
It will boil down to either dropping the whole thing or making two models.
All that was asked for is a simple way to test the water flow through these 3 nettings.
I am opting for two models and just let that be that.
Thank you.
Smitty
Register to Reply 6 comments
MauriceS (1); nukesub629 (1); Smitty (3); Tornado (1)
