Previous in Forum: fastest vehicle   Next in Forum: Why People Shut-Off Petrol Valve of Bike?
ignition advancement
10/20/2009 1:17 PM
Why today's engines need to advance ignition. else these are inefficient?
Re: ignition advancement
10/20/2009 1:33 PM
The same reason as engines have always had advanced ignition, to allow time for propogation of the flame front to allow combustion to exert it's maximum force on the down stroke.
Unless of course I am missunderstanging your question.
10/21/2009 1:21 PM
Dear;
Engine is an oscillating system and as such it is to be enforced when piston stops and changes movement from upward to downward (TDC). Because fuel is supplied as mist and combusts slow only about 7% of fuel has released energy at that point, which maximized pressure acing on piston, without creating too much of it prior to TDC that would stall thye engine. Ther is a balance between paracitic torque generated prior to TDC and max pressure occured in TDC, that starts at that point propelling engine. This ballance relates to proper advancement of ignition.
Stan
10/23/2009 12:20 AM
http://www.youtube.com/watch?v=sEf8va1S7Sw
Among other things notice that what appears to be a large amount of advance is quite a small amount of piston travel.
Register to Reply 3 comments
Anonymous Poster (1); severach (1); user-deleted-1105 (1)
