Previous in Forum: Harmonic analyzer wanted   Next in Forum: water pressure
13 comments
Engineering Fields - Agricultural Engineering - Agricultural Mechanization Technical Fields - Technical Writing - Translator Technical Fields - Education - Fluid Power Uruguay - Member - Born and raised.
A Small Mobile Crane With a Clamshell
10/22/2009 1:24 PM
For a bulk handling application I need a mobile crane, self-propelled, articulated boom, preferably hydraulic, with a clamshell accessory. It will handle fertilizers inside a warehouse.
Actually, I think several units will be needed.
What I want is a combination of the things shown in the pictures, and I am having a hard time finding it.
I am happy.
Pathfinder Tags: clamshell crane grab Hydraulic mobile
Re: a small mobile crane with a clamshell
10/22/2009 1:56 PM
What about an excavator with a clamshell attachment? An even easier version would be an excavator with a regular bucket and a "thumb". The thumb would just have to be solid so the stuff doesn't fall out. It would be similar to a clamshell but only one side of the clamshell would move. Just look for pictures of excavators with thumbs (it is common) and you will see what I mean. Excavators are more plentiful and cheaper than cranes.
The bottom view articulated device that is truck mounted is usually called a "handler". An example is tire handler. You could fit one of these with a clamshell of coarse.
Everything I know about opera I learned from Bugs Bunny
10/22/2009 3:17 PM
Hi DaveB, thanks for the ideas.
I have found something similar to what I want.
http://www.solesbeesequipment.com/Hydraulic_excavatorthumb.htm
http://www.solesbeesequipment.com/excavatorgrapples.htm
Now I am checking suppliers of excavators for this.
I am happy.
10/22/2009 3:22 PM
I'm glad to help. It seems some of the stuff you work on is very similar to some of the stuff I work on, as several posts have shone.
10/22/2009 3:28 PM
Really? What's your work?
I am happy.
10/22/2009 3:36 PM
I have responded to a number of your threads that relate to bulk handling.
10/22/2009 3:51 PM
I know, but I don't remember if you have ever told me what your job is.
I am happy.
10/22/2009 3:58 PM
I am currently a Plant Engineer for a plant that has many bulk applications and previously was a Design engineer for a material handling company.
10/22/2009 4:05 PM
Thanks
I am happy.
Good Answers: 266
Re: A Small Mobile Crane With a Clamshell
10/22/2009 4:42 PM
gussosa the clamshell is just an attachment. The truck can have one put on it. The hydraulics should be there to open and close it. You may have to run hydraulics to control the swivel. You will have to size the clamshell to the truck as to amount of weight it can handle.
10/22/2009 5:58 PM
I know, but I wasn't able to find a supplier who could match all my requirements. Now I am trying to get all the pieces separate.
I am happy.
Good Answers: 179
10/23/2009 10:34 AM
Hello Again and Welcome Back Gussosa,
Did you happen to check with a Caterpillar Sales Rep directly about your hybrid machine? I'm sure they can build almost anything to meet your specifications. Of course it'll cost you your first born and left leg in the process!!!
Ever think of about using an overhead travelling crane instead to avoid hydraulic and diesel fuel contamination of the fertilizer? A leak is bound to happen sooner or later.
Just thinking outside of the "BOX".....
Good luck in your quest!!!!
10/23/2009 10:45 AM
Hi CaptMoosie
It crossed my mind, yes. I didn't do it because it would be too expensive, and also because the current designs by Caterpillar, Komatsu, Volvo, etc, use very delicate electronic controls which don't withstand the corrosion.
My customers usually search around the Mercosur area and even abroad for used equipment, dated before the introduction of electronic controls.
I am happy.
Good Answers: 97
10/23/2009 11:51 PM
Pettybone is what first came to mind then Barko and Tiffin Parts for your special application hardware needs.
Register to Reply 13 comments
bwire (1); CaptMoosie (1); DaveB (4); gussosa (6); ozzb (1)
