Previous in Forum: requrement of bulb   Next in Forum: Undervoltage Conditions and Relay Settings
power factor correction
11/11/2009 10:40 AM
Why does the capactr need to be in paralell rather than in series in order to improve the power factor
Re: power factor correction
11/11/2009 12:04 PM
Consider the capacitor requirement- It will be much higher if the capacitor is connected in series. (I have done a rough calculation, and in that it is almost 3.5 times)
In case of series connection, the whole current has to pass through the capacitor- not only reactive, which anyway it has to accommodate but active too.
11/12/2009 2:54 AM
Because if the capacitor is in series, the equipment will not run.
http://en.wikipedia.org/wiki/Power_factor_correction
11/12/2009 3:34 AM
Series compensation do exist and are the preferable ones in certain cases (eg transmission lines) for obvious reasons.
For other certain cases too these are used
11/15/2009 10:24 AM
When we add a capacitor in series with transmession line , the total impedance of the line (Xt) reduce , therefore voltage drop reduce , i.e. voltge regulation improved , also reactive power is reduce.
Adding capacitor in parallel with load to reduce the current needed (for the same power consumed) , therefore power fctor improved .
Anonymous Poster (2); PWSlack (1); voltage (1)
