Previous in Forum: Reference for Plate Natural Frequencies   Next in Forum: valve disc & seat
Questions
11/11/2009 10:51 PM
what is difference between torispherical dishend,elliptical dishend & flat dishend??????
Good Answers: 101
Re: Questions
11/11/2009 11:09 PM
torispherical dishend: torispherically-shaped
elliptical dishend: elliptically-shaped
flat dishend: flattened shape
Re: Questions
11/11/2009 11:23 PM
A flat dish end (or "head") is self-explanatory. A (hemi)spherical dish end also. If you slice a vessel in half along its axis, you get a cross-sectional view. The flat head is a straight line (or strip). The hemispherical head's cross-section is a semicircle. The (semi)elliptical head's cross-section is half an ellipse; usually the minor axis is half the major, hence the term 2:1 elliptical head. Usually such a head also includes a cylindrical skirt (band) about 2 inches (50 mm) wide all around. A torispherical head consists of a spherical cap (of radius about equal to the vessel diameter) spanning about 80% of the vessel diameter, with a circular arc (called the "knuckle") on either side, blending into a cylindrical skirt. This knuckle arc, when revolved about the axis, forms part of a torus, hence the name "torispherical" for the whole head.
As I recall, the ASME Boiler and Pressure Vessel Code has pictures of these along with the formulas for calculating proper thickness-pressure relationships. Perhaps surprisingly, the elliptical ones are the easiest.
Re: Questions
11/12/2009 4:00 AM
Apart form What explained by other People, These are some additional information regarding different Types of Heads.
FLAT HEADS :
– Used for low pressures up to 5 kg/sqcm
FORMED HEADS :
–Torispherical
•Generally used up to 15 kg/sqcm
–Ellipsoidal
•Generally used between 15 to 25 kg/sqcm
–Hemispherical
•Generally used above 25 kg/sqcm.
Viral Patel
DVader1000 (1); sabapara (1); Tornado (1)
You might be interested in: Flat Belt Pulleys, Flat Panel Displays, Flat Springs
