Previous in Forum: 33 KV system   Next in Forum: IS standard for control panel wiring guidlines
Bulb Temperature
11/12/2009 1:56 AM
Dear all,
There is a bulb (60W) in our bathroom, which gets heated after continuous use of 2 to 3 hours. Do you think, if a drop of water falls on it, it will burst (break into pieces)??
Regards,
PG
Re: bulb temperature
11/12/2009 2:05 AM
Why not try it and see ?
1. Explain why does it happen.
2. As per the green practices replace with CFL - 9W
3. Do not put water on CFL to see - though it will not break - still it will shock you.
4. Anyway if you are going to water the bulbs (electric) - ensure you have an ELCB and in proper working condition.
11/12/2009 2:52 AM
If it's in a bathroom, then it needs to be IP55, so that drops of water don't fall on it.
11/12/2009 2:54 AM
That anti-gravity water is a real pain....
Re: Bulb Temperature
11/12/2009 1:32 PM
It is unlikely because the lamps are designed to be installed and used in areas where some water (and certainly steam and moisture) is present. A spray of cold water may do it thou.
To be on the safe side don't spray the light with water (which I am assuming is mounted in the ceiling).
Anonymous Poster (1); jack of all trades (1); PWSlack (1); user-deleted-1105 (1)
You might be interested in: Rupture Discs and Burst Discs
