I recently purchased an inverter and plugged it in to a dc supply and got an electric shock from a piece of equipment taking power from it. I pat tested the equipment, and it passed ok. I then looked at the inverter itself, when i closely looked at the manual, a small paragraph stated that the earth was floating. It went onto say that the ground should be tied to neutral on this model. After i did this the voltage reading on the neutral line to earth was zero, whereas before it was line voltage.
The inverter is of industrial quality and can be used for marine use.
Why was this not done at the factory, and what is the purpose of a floating earth?
thanks for any replies.
