i know that there is a lot of posts on this subject, but still I would like to hear some opinions. I need to build voltage regulator with N mosfet as series pass. Trouble is that such mosfet has to span 150V with the peak current of 5A. Simply to say there is no a single Mosfet that can do that. My solution are either to connect couple of mosfets in series, but I am sceptical about this solution or to connect in parallel ~5mosfets. Trouble is that their Vgs threshold voltage is anywhere 3-5V and I do not know will current will be equalized since if one conducts 5A at 150V, what is over its limits, my view is that it will burn before other mosfets turn on to share the current, right?
