Previous in Forum: Friction welding   Next in Forum: Free-Cutting Steel Bars and Sub-Surface Defects
Gear Millings vs. Gear Hobbing
11/16/2009 12:21 AM
WHat is the difference between gear milling and gear hobbing?
I am not a home work cheater. I am a translator seeking professional help
Pathfinder Tags: gear
Good Answers: 58
Re: gear milling and gear hobbing
11/16/2009 4:19 AM
I make the assumption that you know what milling means. here is a simple description of hobbing. Hope it helps.
Gear Hobbing
Gear hobbing is a multipoint machining process in which gear teeth are progressively generated by a series of cuts with a helical cutting tool (hob). Both the hob and the workpiece revolve constantly as the hob is fed across the face width of the gear blank.
Process Characteristics
Is a gear generating process that uses a helical hob cutter
Cutters and blanks rotate in a timed relationship
Maintains a proportional feed rate between the gear blank and the hob
Cuts several teeth on a progressive basis
Is used for high production runs
11/16/2009 7:03 PM
thanks for the assist.
Re: Gear Millings vs. Gear Hobbing
11/17/2009 8:40 PM
Gear milling is a multipoint machining process in which individual tooth spacings are created by a rotating multiedge cutter having a cross-section similar to that of the generated teeth (involute). After cutting each space, the gear is returned to its original position, and the gear blank is indexed for the next cut.
Uses a rotating form cutter
Gear blanks are indexed after each cut
Gear teeth are produced individually
Requires deburring
Is a low production process
Is normally used only when generating processes (i.e., hobbing, shaping) are unavailable
Register to Reply 3 comments
Tazzy (1); The Prof (1); wingman1985 (1)
