Previous in Forum: Removing Solar Window Film   Next in Forum: Converting Plastic Wastes to Diesel Fuel
Silver Mirror Deep Processing
11/16/2009 9:13 PM
I deal with silver mirror deep processing,I need to make a sandblasted window on the mirror surface for lighting prupose.Can anyone tell me how to prevent the window side to be free from corrosion as well as the four edges of mirror sheet after polishing.
Pathfinder Tags: silver mirror corrosion
Good Answers: 120
Re: Silver Mirror Deep Processing
11/17/2009 10:41 PM
I am trying to figure out what you are doing.
a piece of glass is sand blasted, the other side is silvered by the classical sugar reduction process. After that, a special pain is applied.
you can also silver the sandblasted side, but it will be less reflectivs.
silvering links, find one you like
http://www.google.ca/#hl=en&source=hp&fkt=3027&fsdt=17059&q=mirror+%2B%22silver+deposition%22&btnG=Google+Search&meta=&aq=f&oq=mirror+%2B%22silver+deposition%22&fp=8a2e5f2ec75fca07
Per Ardua Ad Astra
11/18/2009 3:06 AM
Dear Aurizon,
Thanks for your responseWhat I'm doing is to make a sandblast rectangular window on a piece of silver mirror for lighting,this process destroy the protective paint and the silver layer exposed to the atmosphere and caused corrosion.I need to protect the window edges,what's the best way?
Good Answers: 50
11/18/2009 4:49 AM
Why don't you just spray the clear area with any of a number of clear plastics, like Varithane.
Good Answers: 120
11/18/2009 6:32 AM
Per Ardua Ad Astra
Register to Reply 4 comments
aurizon (2); michaeltso (1); vermin (1)
You might be interested in: Window, Glass and Glazing Services
