Previous in Forum: 2003 Chevy Cavalier - Engine Problems   Next in Forum: Direct Spray Liquid Cooling Systems in IC Engines
2000 cavalier
11/19/2009 1:52 PM
turn signal and brake lights on right side of car do not work
Friend of CR4
Re: 2000 cavalier
11/19/2009 1:53 PM
Have you checked the fuses?
Off to take on other challenges. Good luck everybody! See you around the Interwebs.
Re: 2000 cavalier
11/19/2009 1:54 PM
yes, fuses look good
Friend of CR4
Re: 2000 cavalier
11/19/2009 1:58 PM
Thanks for letting us know that. Can you provide any more information about what you've looked at or things you've tried to do?
Re: 2000 cavalier
11/19/2009 2:11 PM
i turned the right turn signal on yesterday on all it did was buzz, no tinkle noise. So when i got home i checked the fuzes, all looked good. I turned the lights on, all looks good all the way around, except when I turn signal on right, the front and back on right side only did not blink. The brake lights on right side do not work either. I though I needed new bulbs, but AutoZone said it might be wiring?
Re: 2000 cavalier
11/23/2009 11:12 AM
i figured it out. When both turn signal lights go out, it makes a buzzing noise, I just had to replace both bulbs. Thank you anyways.
Re: 2000 cavalier
11/20/2009 11:11 PM
Take the out bulbs that aren't working and inspect them before you rewire the car.
Register to Reply 6 comments
Chris Leonard (2); Franksgarage (1); lwoodstx (3)
