Previous in Forum: How to Calculate Locked Rotor Current   Next in Forum: Can I use a 60hz 230v microwave oven in 230V 50hZ ?
UPS Galaxy3000 20KVA Problem
11/24/2009 3:00 AM
I have a online UPS Galaxy3000 20KVA. It is showing a problem Inverter Ph2 V outside Tolerance. I am checking its LETR board. I am checking its IGBT power module
I have two Questions.
1- If you know the solution of the problem stated above then help me.
2- If you know the checking of IGBT power module BSM35GD120DN2E3224 with multimeter then also help me.
Thanks.
Re: UPS
11/24/2009 3:29 AM
Please give the phase and line voltages of 3 phases. and also furnish the tolenrance what you set. don;t look at the IGBT first, as the chance of IGBT failure is very less.there may be problm with the measuring PT s or the set points or voltage calibration errors.
Please come up with the above details, so that we can give support to sot out
Regards
anand.mandarapu
Re: UPS
11/24/2009 4:39 AM
Phase 1- 222V
Phase 2- 223V
Phase 3- 224V
I don't no how to check and set the tolerance.About two months ago it is working ok I kept it off, now when I turn on the UPS it is showing this fault. nothing is changed
Thanks.
Re: UPS
11/24/2009 7:39 AM
<...don't know how to check and set the tolerance...>
It will be found within the manufacturer's user manual supplied with the equipment.
Australia - Member - New Member Hobbies - Target Shooting - New Member Popular Science - Weaponology - New Member
Re: UPS Galaxy3000 20KVA Problem
11/24/2009 7:32 PM
There are a couple of items I would be checking:-
These UPSs have a Load Balance Tracking system, Check the current (Amps) on each phase, they should be within +/-8% of each other.
Quite often this is a problem on a lightly loaded UPS as it does not take much to exceed the set threshhold.
Next get the Inverter stack checked as a single failed unit in a modular set will also cause this error.
Next Step is to contact APC who now own MGE.
Regards,
Sapper
It's all about the Boom! - MythBusters
11/25/2009 1:40 AM
how to check the inverter as in inverter there are IGBTs BSM35GD120DN2E3224 how to check it individually with multimeter
Ali Saqlain (2); anand.mandarapu (1); PWSlack (1); Sapper (1)
