Previous in Forum: Brown Coal Dewatering -Overview Techmology-   Next in Forum: thin walled elasromaric tube
Jig for Designing Solar Cooker Reflectors for Unattended Cooking
12/01/2009 11:32 PM
Solar cooks have 2 main choices, Box cookers that are slower, more reliable and that you can leave unattended and Parabolic cookers which is faster but needs to be adjusted lots. You generally cannot leave it unattended because first the food may burn and then the focus will move away from your cooking pot and your food will get cold.
Box cookers win so far because, who wants to get sunstroke watching a pot and also get the sun's image burned on their retina?
Solar cooking is being pushed now because it can save a lot of forest from the cooking fires if it is done right. I propose a simple way to design reflectors for better unattended solar cooking.
Faster than the box, more reliable than the parabolic and unattended.
I put 2 videos on youtube to further explain what I am trying to do .
They are http://www.youtube.com/watch?v=NFjuoDVU4c8 and http://www.youtube.com/watch?v=xbiVo12kuKA It helps to watch the first one before seeing the second one.
but if you are short on time, the first 5 minutes of the second one should be explanation enough.
Brian
Pathfinder Tags: Cooking green solar
Re: Jig for Designing Solar Cooker Reflectors for Unattended Cooking
12/21/2009 12:42 AM
It is really just a t-square with laser pointers attached on a track so they can slide to different positions.
The laser pointers simulate the sun at the start and at the end of a cooking period. It means that you can design non tracking solar cooking reflectors with 1 hour, 2 hour, etc cooking times. (It is necessary to bounce the light more than once to do this).
Any engineers care to comment on the idea?
Brian
01/09/2010 12:06 AM
http://solarcooking.wikia.com/wiki/Solar_design_T-Square
is the newest page about it. The T-square actually works really well . I found it too hard to work with the mylar that I have (too crinkled) so while I wait for more, I made a model with little mirrors from a craft shop and with clay as a backing material so I could set them in position. That worked.
The model is kinda like a clam shell in shape. I think it would also work with a 2 shell "open clam" design. The one I show should be good for just over 2 hours of solar cooking at good pretty even power.
Anyway, might as well give up posting. Nobody is interested.
Brian
Register to Reply 2 comments
You might be interested in: Solar Water Heaters, Solar Mounts, Parabolic Mirrors
