Hi,
I am in the UK at the moment. Can anyone advise of the exact type of the fuse mentioned below: Once I know the type I can order a couple. I need one only, but will order a spare.
Replacement fuse: T3.15AL250V
Physical size: 20 mm long x 4.5 to 5 mm in diameter. I am shaking so cannot measure the exact dia' sorry.
It comes from a Shredder and I think it is a Time Delay Fuse.
Why a "Time delay fuse" would be necessary in a shredder I do not understand.
I need to know before I can search for a couple.
It looks like glass with something that has melted inside it. Normally I can see through the glass and see a broken wire, which is the fuse, but this is a black plastic or bitumen which has melted and shattered the glass in places with the bitumen holding it together.
I thank you for your time.
bb
