Hello All,
Perhaps some of you good folks in CR4 Forum may have an old oddball or obscure textbook, handbook, paper or what have you that outlines the methodology of the Working Stress Composite Analysis for fully-concrete encased steel wife flange beams and girders. I've been tearing my hair out trying to find such a methodology in my textbooks, handbooks and on the www, but to no avail. All that I've found so far for my efforts has been the procedure outlined in the AISC LRFD Handbook. Not exactly what I was looking for.....not going there!
Currently I'm investigating an existing building floor girder that is not quite fully encased in concrete, and appears to have failed, and now is exhibiting very pronounced deflection under dead load only conditions. Building was erected circa 1927 and steel framing member, as field measured, is best matching a B16, 35plf wgt., and most likely conforming to ASTM A-9. Windsor probe testing of slab for compression strength is scheduled for this upcoming Monday AM. I want to perform the analysis of the section to verify (and to satisfy my curiousity) if it were initially designed as a composite member or not, or if possibly a design or an erection error may have occurred during construction.
There must be some obscure structural engineering textbook or white paper or software available somewhere in the world that can be scan and emailed to me. The procedure must be outlined in English and follow the Working Stress Method for determining composite properties----------------
This is one of those obscure instances where you wish you had photocopied an old structural handbook years and years ago.........Well, now I'm practically kicking myself for not doing sosome 20 years ago, the last time I had to perform such an analysis!
Many thanks in advance for any assistance that may be rendered!!! Have a very Merry Christmas or Hanukkah or Kwanzaa!!!!!
