Previous in Forum: Water Hammer in a Fuel Line   Next in Forum: Alternatives to AutoCAD 2006
Engineering Fields - Agricultural Engineering - Agricultural Mechanization Technical Fields - Technical Writing - Translator Technical Fields - Education - Fluid Power Uruguay - Member - Born and raised.
Inspecting Back-Hoe Excavators in Italy
01/17/2007 10:25 AM
I am participating in a public tender and the customer asks for the names and quotations of at least two quality control companies. One of them will be chosen to inspect the excavators two times: one in-factory and the other one at the port, prior to the shipment. My supplier for the excavators is in Ravenna, Italy.
It isn't really a quality control work. The inspectors must check the reality against the specifications of the customer and report whether the products comply or not.
I think a Mechanical Engineer with experience in back-hoe excavators is acceptable for this job and the customer can't say much against it.
If you are an Italian engineer or just know of a company as I need... please contact me!
I am happy.
Engineering Fields - Piping Design Engineering - Environmental Contractor United States - Member - Born, raised and proud to be Texan Safety - Hazmat - New Member
Re: Inspecting Back-Hoe Excavators in Italy
01/18/2007 8:54 AM
Have you considered using a large construction firm or an equipment rental firm. Either maintain equipment fleets and may allready be familiar with the excavator's you are purchasing.
Believe none of what you hear......and only half of what you see.
