Previous in Forum: Relationship of "4gig" to Broadcast Signal   Next in Forum: Wireless boost to gaming console in play room advice
Rectifier
01/06/2010 10:19 AM
hi everyone, i rectified a AC signal using a a half wave rectifier, when i measure the current at the output, it seems to fluctuate(keeps on changing about +- 10mA from the actual value).
im using a multimeter to measure the current, i set it to DC mode since i already rectified it to a DC from AC using a half wave rectifier.
The value of the current should be around 150mA. but now my multimeter shows that the value keeps on changing from 140-160mA. It wont stay still at a certain value.
can anyone tell me how to solve this problem?can this be solved if i use a full wave rectifier instead of a half wave rectifier??? thanks for replying.
Re: Rectifier
01/06/2010 11:10 AM
put a full wave rectifier (optionally)
Put a proper low pass filter to filter off the pulsation.
Re: Rectifier
01/06/2010 11:14 AM
A half wave rectified signal varies in amplitude from zero up to a maximum voltage.
With your multimeter set to ready a steady dc current (or voltage) the internal Analogue to digital converter sees a varying signal, which it doesn't like.
Most multimeters have the A/D clock set to cancel out mains frequencies as much as possible, but what you are doing is using it on dc to measure a ½ ac waveform, so its confused and will give invalid readings.
Look up the form factor of the half wave rectified signal and you will see its a miracle it reads anything sensible!!!
Re: Rectifier
01/06/2010 2:40 PM
Rectified AC is not DC, it's just the positive halves of the sine wave AC, so your meter may not be able to accurately measure it. The first question I have to ask is, what load are you using? You need something nice and linear, like a resistor. If you're driving a load some distance away, and that load is non-linear, such as semiconductors, you may be getting a low frequency oscillation of the power due to inductance in the lines. This is extremely common. The solution is a large electrolytic capacitor at the load (or radically shorten your lead wires).
What I recommend is,
1) If you have access to one, look at the rectified voltage on a scope, or
2) Put a smoothing capacitor (a big electrolytic one) on the output to convert the rectified AC to real DC.
Does your meter show the voltage to be flucuating as well? If your load is linear, the current can't be changing unless the voltage is also changing. If you have a linear (resistive) load, and the DC voltage is constant, you can disregard the fluctuations of your current meter, and blame the meter.
Good Answers: 18
Re: Rectifier
01/06/2010 10:59 PM
It sounds like you're using an inverter without a power-regulation IC (integrated circuit) right after it.
A half-wave rectifier will enable most of a half-cycle of current to be fed into a capacitor, which will be downstream of the diode that will allow the current through. The capacitor charges up if the line voltage minus the voltage drop across the diode and the resistor between the capacitor and the diode is greater than the voltage across the capacitor.
Once the capacitor starts to charge, it'll keep doing so until the crest of the line voltage will be reached. Past that point, the capacitor starts to discharge into the load, thus decreasing the voltage across the capacitor leads. If the load is a pure resistor (no inductance, no capacitance), then the voltage across it will drop as the capacitor's drops, the current passing through it will drop in proportion, both until the capacitor starts to recharge during the next half-wave. That's why your current reading bounces up and down ... your current's magnitude really DOES oscillate.
The way to eliminate these oscillations is to stick a voltage-regulation IC (integrated circuit) just downstream of your rectifier's capacitor (so between it and your load). National Semiconductors and a whole lot of other manufacturers make these.
Cheers!
DZ
Do unto others. Then run.
Re: Rectifier
01/07/2010 5:16 AM
Using a full wave rectifier would improve the situation. Adding a big filter capacitor (big electrolytic) is also a good idea. The reason for the fluctuation is that the half wave rectified current is pulsating. Your digital meter samples the current periodically and the sampling times occur at different parts of the waveform and give you the fluctuation.
Re: Rectifier
01/07/2010 6:27 PM
Google: Pi filter and build one and put on output of the rectifier.As mentioned, a full-wave bridge is more efficient.A half-wave rectfier will only give 30 hz pulses, a full wave will give 60 cycle pulses,and a full wave bridge will give 120 hz pulses.Much smoother and easier to filter.The capacitors in the Pi filter stabilize the voltage, and the chokes stabilize the current.
Good luck with your project.
HTRN
Register to Reply 6 comments
Anonymous Poster (2); bhankiii (1); DreadZontar (1); Electroman (1); HiTekRedNek (1)
