Hi all,
I have a design application where I want to reduce the speed of a 10HP engine (gross torque = 14.5 ft-lbs, max 3600 RPM) about 6 times at the rear axle, so 6:1 basically. We don't have much space to put all this into. We're also using a CVT clutch with a 4.5:1 in low ratio and 1:1 in high ratio.I have two options :
1) A two stage gear reduction of 3:1 and 2:1 for a total of 6:1, using sprockets and chains, which I'm leaning towards.
2) A planetary system which I don't know much about. All I do know is that if your input is at the sun gear and output on the ring like we would like it to be, the direction of rotation is reversed so we would probably need an intermediary idler or something in there to equalize directions.
Does one of the two have an advantage over the other in terms of power transfer, efficiency etc?
If I leaned towards option 1, standard chain design literature tells me that I need to have a 30T-90T pair of sprockets for the 3:1 stage alone (ANSI 50 chain) for a "heavy shock" load classification of k=1.7. Given the space constraints I have, I can't go for that big a pair and I'm thinking of a 12T-36T for that stage instead. Then the question is, how much will I lose in terms of a "fail-safe" design if I ignored chain design literature. The chain probably won't fail but its the wear and stresses on those small sprockets I'm worried about. Should I go for a double-strand chain?
Of course, if planetary is a superior option, I wouldn't have to worry about all that but I have little expertise there. Please help. :)
