I want once for ever stop the different discussions about GA and the way they can be interpreted.
I made a correlation between the number of comments and the number of GA's obtained and came to an interesting result based on over 30 pairs of values for more or less active "members" it is not a full analysis but the trend is clear.
The above picture shows that without selection of the participation the higher the number of comments the lower the relative number of GAs with a trend to ≈2% of total.
This means that the "value" of the Gas number is totally not significant, the only aspect it shows is is the participant enjoys or not the appreciation of the others.
The participant with the highest number of comments at the moment I made the analysis is Del who deserves a special mention for the intense participation!
Follow PWSlack and Andy all of them with ratios around 2%, of course it is valid only for the sample I took. I have neither the time nor the intention to make a full statistical analysis.
The only comment I already made is that the answers we give are often directed to a very narrow field of interest and many times ONLY the one who asked the question gives a GA. I think that at least the only possibility to appreciate the value FOR the OP is to mention also the number of answers with 1 GA.
So that the more you discuss the less you are worth (relative)!
I hope we will not discuss any more the subject.
NIckname
