Am trying to develop a solution to move 2 Two Tonnes pedestals in the linear direction
Distance of travel of each Pedestal : upto 300 mm
The Pedestal currently rests on a floor base whose surface roughness has predictably deteriorated since being installed possibly 20 years back and any attempt to move the pedestal over the surface overcoming friction is a time consuming activity involving deployment of gantry cranes to lift the pedestals and placing them at a distance that often is no more than 300 mm from its original position.
We had earlier suggested that the pedestals be placed on an array of rollers mounted on the floor so that any contact with the floor is completely eliminated. This solution was unacceptable to the people concerned as they insisted that the pedestal must rest on the floor when tests are carried out on the components that is clamped on the pedestal after the pedestal has been properly positioned.
However they clarified that they did not mind if the pedestal is lifted off the ground for movingit into proper position & then lowered back onto the floor once the desired position is reached.
Our proposed solution involves placing the roller arrays in slots cut on the floor. In normal position, when pedestal is not to be moved, the array is recessed in the floor [possibly at a level that is slightly below the ground level] and is not in contact with the pedestal that would then be resting on the floor base as normal.
[p]Once it is decided to move the pedestals, a mechanism is activated by means of which the roller array moves upwards coming in contact with the pedestal base, lifting it from the floor [feel that lifiting the pedestal by around 20 mm above the ground should suffice for the purpose of its movment] making the pedestal to now rest on the rollers, making it easy to push it either manually [human operators - current practise] or mecanically [yet to get approval for the automating/mechanizing the movement].[/p]
Would imlementing such a solution be possible?
Qualitative aims we intend to fulfill
1. System must be robust not prone to frequent breakdowns
2. Solution must be economical
3. Solution must be easy to operate
4. Amount of cutting involved fro making the slots for placing the arrays must be kept to minimum - both in terms of width of slot & depth of the slot cut.
Taking into account all these, we intend to propose a solution that would involve lifting the rollers from its recessed position to lifting the pedestals using a Hydraulic system.
Frequency of moving the pedestals: around 2 times a week
Our query:
1. Would it possible to deploy such a system that would satisy the qualitative requirements sated above?
2. Would it be possible to use a hydraulic system given the space constraints of allowabe dimension of slot that could be cut on the ground
As possibly evident from my queries, we are in the final year of our undergraduate course of Mechaical Engineering & have taken up this project as part of our fullfillment of requirements of our course.
Having no prior practical experiance in developing systems for industrial application, we also realise that htere is a wide gap in the therotical knowledge that we imbibe in College and the actual standardised practices in the industry. We hope to bridge this gap through the knowledge of the ofrum embers who participte here[br/]
Seeking the guidance of esteemed forum members whom after years of lurking on this forum & reading their posts I've come to greatly admire & respect.
TIA
