Previous in Forum: Determining Input and Output Power   Next in Forum: Calculating the Number of Poles and Motor Terminal Voltage
Calculating Starting Torque
03/01/2010 1:00 AM
When stared direct on line a three phase squirrel cage induction motor develops a startring torque of 120Nm, When started by an auto-transformer starter, the starter draws 48 amps from the supply and the motor draws 8- amps from the starter. Calculate the value of the starting torque developed by the induction motor when started by the auto-transformer starter.
I am looking for help to better understand my math in my electrical course. The tafe lecturere is no good and I'm having trouble with some of these questions. I am hoping it will be explined in simple terms which will allow me to then practise on the many other questions I have to fill out. This is just one example of them.
Re: calculating starting torque
03/01/2010 2:19 AM
the starter draws 48 amps from the supply and the motor draws 8- amps from the starter ?
03/01/2010 2:39 AM
sorry the 8- should be 80 amps
03/01/2010 10:09 AM
Eh? Where did those other 32 amps come from?
03/02/2010 4:16 PM
I don't know.. that is how one of the questions is written... I'm only asking for help on one question.. I have another 10 to do myself...
Re: Calculating Starting Torque
03/01/2010 10:41 AM
Belgium - Member - New Member
Good Answers: 21
03/02/2010 5:31 AM
New starting torque is 43.2 Nm ????
03/03/2010 4:57 AM
In a reduced voltage starting (eg with auto transformer)
starting torque is reduced by the square of voltage eg you reduce the voltage to half, the torque reduces to 1/4th.
In case of auto transformer (or others too) you vae the equation,
V1I1 = V2I2
Even if you dont knw the voltages, you know the voltage reductions and hence torque reductions?
Register to Reply 7 comments
allyrat (2); Anonymous Poster (2); jhonson (1); PWSlack (1); rudy.leurs (1)
