- Can the following be used transmit mechanical power from one shaft to another located far apart– at high speed and high power levels?
- Advantage being no fear of belt loosening or wear and tear, breakage.
- Alignment between the wheels need not be in the same plane one could even think of more complex geometric coupling.
- More tahn one wheel could be coupled easily to same gear by simply placing more couplers.
- Instead of soft iron solid can soft magnetic fluid be used for more 3 dimensional coupling?
- Gear teeth shape need not be complex involutes. Gear teeth could be far simpler geometry.
- Pole faces can be suitably shaped to provide repelling and attractive forces.
- What are the advantages / disadvantages, limitations do you see?
Pathfinder Tags: automotive
